Hi. I have a coupe quattro with an MC swap and i am planing to change my gearbox to 6 speed 01e. Do i need to cut the propshaft or i can use another one from other chassis? how about the driveshafts? I've seen others moved the subframes. I can score an 2.5tdi c5 transmission for good price. It's an AEK code. Do you have any info about this box? Final drive ratio? Thanks a lot
6speed 01e swap in b2 cq ?
Originally posted by bn-01-wso View PostHi. I have a coupe quattro with an MC swap and i am planing to change my gearbox to 6 speed 01e. Do i need to cut the propshaft or i can use another one from other chassis? how about the driveshafts? I've seen others moved the subframes. I can score an 2.5tdi c5 transmission for good price. It's an AEK code. Do you have any info about this box? Final drive ratio? Thanks a lot
If so then you will also need to change out and modify the speed sensor so it drives the mechanical cable style speedometer in the B2 instruments. I had someone do this recently for a conversion here - needs a small bit of machine work done on the B2 speedo drive to make it fit in the 01E gearbox. I have some pics & descriptions stored somewhere if it helps.Paul Nugent
Ahhh - ok - perfect then... you should be good although there are two types of electrical speedo sensor - pretty sure the one you already have will bolt into 01E though.Paul Nugent
I am pretty confident the B2 driveshafts and propshafts will bolt onto 01E, but I am not the expert on this one... Others will have surely ventured before you. The propshaft might need to be a different length.Paul Nugent
You can keep your propshaft, but you will have to find the right length of the driveshafts from the scrapyard searching between b2 and b3 front driveshafts.
It will be easier if you change 01e output flanges to 100mm units from 016 gearbox with a little shortening from inside to allow flanges go deeper into gearbox. How much? You will see yourself. Then you can use b2 CV joints and driveshaft.
108mm was a different story as I didn't have that much driveshafts to choose from.
Gear selector? Google motorgeek 01e b3 and read that topic to get the answer. Don't get confused about topic title.Last edited by Val; 25 September 2014, 18:29.5vtq gte
i have build a o1e gearbox in my b2 coupe quattro and the 016 box is longer than the 01e so you need to make a adapter flange for the propshaft
for the drive shafts,as they have said,i put the 100mm flange from 016 box on the 01e box but they need a little bit machined for fitting
for the driveshafts i have taken the origional one and machined this to fit on the car
for the shifting mechanism,i used inside a modified urs4 shifter for 6 speed en adapt the origional shift rod that goes to the gearbox but you need to switch than the balljoint on the gearbox because on the 01e it's bigger than on the 016 box
be carefulle with gearratios and diff ratios!
i believe that an urquattro gearbox and diff has a ratio of 3.89,a b2 coupe quattro has a ratio off 4.11 and the most 01e boxes also have 4.11. check this !!
good luckaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injection
Thanks a lot. Maybe u used a 5speed 01e? Probably the 6speed is longer? I have to check my diff code to see the ratio and then buy the gearbox with proper ratio. From your knowledge what would be the best ratio for better acceleration? I know that the RS4 B5 and B7 also use the 4.11 final drive ratio. Thanks
