A4 quattro rear hubs on the front of 80 tdi??
  • Val
    • Apr 2008
    • 630
    • Country: Latvia
    Pajautā a|s spamā
    5vtq gte
    • Kermps
      • Oct 2011
      • 55
      S2 discs won't work with your current calipers which I believe are made for 256mm disc. S2 discs are 276mm. So you definetly need g60 calipers. I have heard that b5 1.8t quattro front calipers should fit too.
      Atm I don't have any pictures of drilled discs.
      • mortcars
        • Jun 2008
        • 82
        Holy Thread resurrection!
        any reason i cant use the front hubs/arms/driveshafts off a 4cyl B5 A4 quattro to do the 5x112 front swap?
        '89 B3 Coupe 2.3E Auto / Gone
        '92 S4 Avant Auto / Gone
        '92 80 B4 Saloon 2.0 Auto / Gone
        '93 80 B4 Tdi Avant - Daily
        '96 A4 B5 1.9Tdi SE Auto Saloon / Gone
        '97 A4 2.8 V6 Quattro Saloon / Gone
        '97 VW T4 LWB Hightop Camper
        • _ShurikeN
          • Mar 2010
          • 733
          • Country: Russian Federation
          The reason is dramatically low height of the hub (offset).
          You could do it if you sort out all the offset issues. For instance by manufacturing a proper spacer.
          • mortcars
            • Jun 2008
            • 82
            so a set of hubcentric 20mm spacers would do it? and the disc/calliper will be all ok?
            then i can just order 2 pairs of spacers and thats it sorted
            edit: just looked at the pics again, do the spacers not sit on the disc? you show them on the hub itself?
            • _ShurikeN
              • Mar 2010
              • 733
              #21
              It's hard to answer the questions definitely. just "any" universal hubcentric spacers won't do the job, of course. The spacer in intended to be between the hub surface and brake disc if you are inclined to use the existing brakes and keep the existing brake disk height. But you don't have to.
              That is just an option and not the very best in my opinion. And not the cheapest btw.
              • sam80quattro
                • Oct 2006
                • 1496
                i tried to fit a4q rear hub into my 80 tdi front hub carrier today and the a4 hub has a outer of 43/45mm so they wont fit into the 75mm od wheel bearing as the inner of that is 39/41mm..
                is there a 75mm bearing with 43/45 inner diameter?
                • sam80quattro
                  • Oct 2006
                  • 1496
                  • mortcars
                    • Jun 2008
                    • 82
                    when i was looking into this you needed the v6 front wheel bearings, best way is pop to your local motor factors and get them to bring some out and have a measure, or is it poss to replace the drive shafts to correct the size?
                    • sam80quattro
                      • Oct 2006
                      • 1496
                      the v6 bearings are 82mm od.. I was hoping there was a bearing with 75mm od and 43/45mm id??
