Ahhhhh! So I have had real bad luck with gearboxes. My original urs4 box was noisy in first so I bought a supposed good v8 s4 box off the forum. It was noisy in almost every gear. When I did my stroker build I bought a reconditioned rs2 box off the forum.
This rs2 box seemed good when I got it but my exhaust was a bit loud. I then quietened down the exhaust and immediately noticed a ticking noise on the overrun in 3rd. Not loud but defiantly there. It's speed related and doesn't go away with the clutch depressed. Putting my foot on the throttle seems to quieten it up. All other gears seem fine.
I had noticed a small leak from the area near the prop shaft flange at the back which has got much worse. It seems to really piss oil out when the car is driven hard, to a point that oil on the exhaust went on fire and scared the **** out of me!
So are the 2 issues likely to be linked eg a shaft moving causing the noise or have I 2 faults. As the leak gets worse when pushed eg full power through second etc, is it a sign of a bearing allowing the output flange to move and let the seal leak worse?
I'm feed up with gearbox issues! Cheers des.
Sent from my SM-G900F using Tapatalk
