After replacing my gear stick lower joint & socket, I'm still not entirely happy with the shift on my 6 speed and there still seems to be play in the linkage somewhere. My thought was that its the plastic bush at the end of the linkage that's to blame for the sloppiness. After reading through some older posts, I found the original part number for the bush is 8A0 711 189. So now I think I have two choices, replace the plastic bush with one of these:
(although I don't know if this actually IS the correct bit)
or, one of these:
http://store.034motorsport.com/shift...e-6-speed.html
I've heard that the 034 stuff can be tricky to install and adjust correctly so replacing the bush with a standard one may be best?
Anybody tried the 034 kit as above and can comment on installation or can confirm I'm looking at the correct bush? The bush isn't terribly expensive but I don't want to waste 20 odd quid if I can help it...and don't want to buy the 034 kit if its going to take a day's labour to install...
Any input always appreciated chaps
cheers,
mike
or, one of these:
cheers,
mike
