ABY FW Centre / Spigot / Pilot Bearing
    Just got the engine back and the pilot bearing (ABY) that I bought doesn't fit the 7A flywheel that I have. I'll find out when I take the engine out but I'd swear that the 3B flywheel shares the same bearing as the ABY I did research it and obviously got it wrong. Is it an issue at all? I'll get a 7A one.
      Hmm, I thought they were the same too..
      Are you sure you got the right one there?
        As I say, I could swear blind that the 3B and ABY are the same but this is a 7A and originally had the sealed ballrace bearing fitted rather than the ABY style bearing.
        The hole is a 1.5x larger approx. on the 7A one I have, so I'll have to source the correct bearing. I don't see it being an issue, just seems odd!
        May need to use the parts list created 8 years ago when I first did the conversion to make sure I get the correct dowels etc.
        • GazzaG60
          • 4133
          heres hoping for no noisy bearing as I just fired and forgot
            Anyone got a source for the 7A bearing?
            Sachs 1863 869 004
            SKF 6202-2RSJ
            • K Simmonds
              • Dec 2007
              • 7632
              Bestcarparts could be worth a try, that's where I got my OE Sachs 3B one from.
              Edit, just realised your talking about the spigot as opposed to the release bearing, durr.
              I could be interested in the one you have surplus to requirements if you can confirm that it's going to fit a 3B? May as well change that as well whilst I'm in there, which hopefully should be soon... finally.
              1990 B3 2.0 80 quattro.
              1992 C4 2.8 Avant quattro
              1994 MTM RS2.
              1998 B5 TDI quattro Sport.
              2000 B5 TQS.
