AEL FrontWD gearbox issue
  • Giacomo
    • Apr 2014
    • 523
    • Country: Italy
    Hi,
    I have a C4 AEL front wheel drive with an issue on the gearbox.
    It makes noise like worn toothgears.
    My question is: could I swap a 4wd gearbox, and leave the shaft fitment run free under the car?
    I guess 4wd gearboxes much easier to find.
  • caterpillar
    • 2480
    you may use any audi fwd tranny.. they will fit too.. you may use the q tranny too.. but its easyer to fit the right one...
    • Kieron20V
      • Mar 2008
      • 1505
      In short, no. It would be like trying to use a fwd gear box with only one drifeshaft connected. Except you'd get 50% of the touque transmitted, and a very hot torsen diff. Has it got any oil in it?
      1994 URS4 Avant RS2+
      • Zoig
        • Sep 2008
        • 555
        fwd with quattro gearbox would just not work. Think how torsen would work if there is 0 torque on propshaft output and you will get the idea. Get the gearbox/diff fixed or buy new fwd box, simple as that.
        • Giacomo
          • Apr 2014
          • 523
          • Country: Italy
          ok thanks, I'll start opening the gearbox and see what's wrong in details.
          Then, see what to do.
