Rear LSD
  • audiman
    • 4827
    Rear LSD
    Where the hell can you get one of these?? Ex rally stock??
    Can the original one be converted into one??
    I want some drifting fun
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
  • s2driveruk
    • 12696
    wait for the snow to fall tonight, get out to a big carpark, lock yer rear diff and drift saves a ton of cash ;-)
    1992 3b S2 Coupe
    • Habib
      • 316
      • Home: United Kingdom Current: Italy
      Just buy one of these instead
      • Beetie
        • Oct 2003
        • 1517
        When my mate had a mk2 escort they used to use one off of a jag..... Might be a bit old for these tho!
        Was a '93 3B, Dont ask now tho......
        • Henka
          • 585
          • Home: Sweden
          What about Quaife? Also, just like you actually said yourself - check ads for ex rally stuff.
          • Mihnea
            • 1288
            Tom, the rear diff can be turned into a torsen if that's what you're after... I'm gonna need one in the S4 soon too...
            www.MRCTuning.com
            info@MRCTuning.com
            Workshop Directions
            • Henka
              • 585
              • Home: Sweden
              Öh? How are you going to turn a standard rear open diff into a Torsen differential? You mean switched to a Torsen?
              • Mihnea
                • 1288
                Turned/switched into a torsen, this is semantics. It can be done, and we will do it.
                Mihnea
                www.MRCTuning.com
                info@MRCTuning.com
                Workshop Directions
                  Henka - take a look at the transmission section on S2central.net in the technical chapter. There's an explanation of the various diff types.
                  The standard (open) front & rear diff casings can accommodate Torsen or Quaife-ATB type differentials. I hope this is something that MRC make considerable attempts to productise such conversions.
                  Paul
                  • caterpillar
                    • 2480
                    look at the yard,they have wrecked car there,where you lives too..... look for the audi v8 from the 89-94..... they may have the lsd diff. they don't have the locking unit outside.....
                    • s2_southwest
                      • Oct 2004
                      • 823
                      I know Quaife are listed in the demon tweeks motorsport cat, and list one for the coupe quattro etc...
                      Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
                      • NoNonsense
                        Forum Sponsor
                        • Apr 2004
                        • 673
                        i've said it before, and i'll say it again...hehehe...the torsen from the Audi V8 can be placed within the casing of the B4/5 casings...i've seen it on a couple cars in person. I know that you know Mihnea, but everyone else doubts...
                        Joe "NoNonsense"
                        axis motorsport
                        joe@axismotorsport.com
                        "At the end of the game, the king and the pawn go back in the same box."
                        • Henka
                          • 585
                          • Home: Sweden
                          Yes I know. You can switch to a V8 Torsen. Look in the post. I've written alot of questions and answers under that thread. It just caught my eye that Mihnea here was saying you could turn an open diff into a Torsen
                          I just wanted to know what he meant. As I said, I knew you could "switch to", not that you could "turn into".
                          • Baldy
                            • 469
                            • Home: Sikkim Current: British Antarctic Territory
                            You could always try 1 of these
                            dodgy strange LSD thingy
                            Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                            0-60 4.9
                            1/4mile 13.5
                            • Henka
                              • 585
                              • Home: Sweden
                              Yeah... Those things have been around for ages. The GOOD thing about them is that you add 2 more spider gears in the differential bringing the loads on the gears down as one wheel i spinning and one is standing still. Now, this one seems to be a combination of that AND a Gene Breg Poor Man's Posi Traction (anyone know Gene Berg? If not guess you're not into VW Beetles then!). Basically what you do is shim the play between the spider gears in the diff so that the backlash in them is veeery close to zero. The added friction in the gears now mean that as power is loaded on in the diff it is easier to spin both wheels than one - and the extent to which this happens is, as I said, adjustable by shimming. Basically what you end up with is a diff that is still open but beefed up (4 spiders instead of 2) with some possibility of lsd-function - in my mind it can't be all that much though.
