Rear LSD
  • audiman
    • 4827
    Fantastic info!! Nice on, well im searching for a V8 diff now. Its got to be done, might even use a Quaife diff in the front on my spare gearbox.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Josh-stateside
      • 741
      One of the guys on the forum installed torsen on his front wheel drive v8 coupe gt.
      Really no need for the quaife if you can find the v8 torsen diffs.
      In my opinion.
      • puppetman
        • 70
        #33
        for us unfortinate ppl in the USA, what all will we need to change to make the v8 torsen work. . i hate understeer
        • Josh-stateside
          • 741
          Are you asking a question? I'm confused?
          • The Spanish
            • Nov 2003
            • 719
            #35
            Hi Tom.
            I am also looking for a V8 diff. So if you know of more than 1 please let me know.
            So far I have found a whole Audi V8 for 1400 Euro
            Is even less that the 1800 the stealer quote me for just the diff
            I am trying to find alternative ways of doing it. And Stasis webpage seems nice. Maybe Us guys can comment on it.
            94' RS2 Coupe TT (Twin Torsen )
            • Albert
              • 1500
              • Country: Poland
              #36
              In my opinion.
              Can You get more details ? I would want to get front torsnen also.
              AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
              • Josh-stateside
                • 741
                "My V8 CGT has a torsen in the front. It's very easy. The case cover on the tranny needs to get hogged out to accept the larger bearing. The torsen cap is hardened and turning it down to accept the smaller ID bearing would be difficult.
                There is a notch in the bottom of bearing race seat in the case cover... I couldn't figure out exactly what that was for. You can't retain it when you bore the case cover, but you should have no adverse affects."
                How's that? If you need more info I can send you his email address.
                cheers
                Josh
                • Albert
                  • 1500
                  • Country: Poland
                  #38
                  yes, please
                  • s2-1.5bar
                    • Sep 2004
                    • 193
                    • Home: Lithuania Current: United Kingdom
                    #39
                    Can't remember the locking options on a UR - but from memory the non torsen equipped cars (WR engines) could lock the centre and rear. Later cars with torsen centre (MB & RR) only had lockable rear IIRC...
                    Paul
                    Yes Paul, u r right.
                    U can lock centre diff first, and after if u need rear diff. The locking lever has 3 positions in total.
                    UR G/box is way to short for S2 engine, but the way u can lock diffs is great.
                    Andy
                    • The Spanish
                      • Nov 2003
                      • 719
                      #40
                      Work in progress of rear v8 Torsen diff mountin here
                      • Billman
                        • 4129
                        #41
                        Hi, can someone please give me the dimentions of the V8 rear diffs crown outer and inner diameter and screw hole distances, the outer and inner diameter of the gears and the thickness of them!
                        thanks!
                        Go Holset or Go RS4
                        • The Spanish
                          • Nov 2003
                          • 719
                          #42
                          I could in a week or two time, but is the same crown&Pinnon of any S2 Avant, Saloon or RS2 so you should have more to look and I am pretty sur that Coupe and Avant have the same crown but different pinnon.
