Recognize this?
    Recognize this?
    I know what it is. I am surprised that it failed in this way. Any BTDTs?
    Less obscure:
  • david1980
    • May 2014
    • 1027
    flywheel bearing?
      Originally posted by david1980
      flywheel bearing?
      Close. Be more specific.
      • david1980
        • May 2014
        • 1027
        flywheel needle bearing i think its called?
        • shaun5
          • 1610
          spigot bearing
            Originally posted by shaun5
            spigot bearing
            Item 14A inside ("needle bearing" (3B/ABY (and AAN and ADU))
            http://audi.7zap.com/en/rdw/audi+cou...05-105020/#14A
            Any BTDTs? Or speculation on the reasons for the failure?
            • A1QSHIP
              • Aug 2004
              • 975
              Original? I have seen these fail at high mileage on cars with mostly in-town driving.
              "Nulla tenaci invia est via"
                So that implies that the number of clutch engage/disengage cycles would be very high and that somehow this fails the bearing. Almost seems like the rollers need lubrication where they contact the transmission shaft because otherwise, the shaft is trying to drag the rollers (needles) out of their housing on every cycle (?? )
                OE:
                Aftermarket:
                REF: http://www.ecstuning.com/Search/Site...034_105_313_A/
                • 90quattrocoupe
                  • Nov 2003
                  • 771
                  I would think that any bearing would need lube of some sort. Maybe something like a molybdenum disulfide paste. Something that would not seep like grease, but a paste would stay put.
                  Greg W.
                  • SteveH
                    • 4460
                    Looks like it just got old and the grease escaped, then the bearing disintegrated. I've always added some grease to mine when refitting the gearbox
                    91 Modded 3B
                    14 A6 Avant Black Edition
