I run a 01A flywheel with 01E gearbox no spacer plate between box and engine will a rs2 clutch fit onto my set up or is the pressure plate /cover to fat
clutch question
I think there is a photo on the forum somewhere with all clutch/ flywheel combos and their associated stack heights.
I think rs2 clutch and single mass flywheel you should be ok, you run into trouble trying to run a dual mass and full height pressure plate. AAN uses a dual mass flywheel with a lower profile pressure plate. Safest bet would be to use one of these, or an updated version if you need rs2 torque capacity.1994 URS4 Avant RS2+ -
Clutch question II
I have an AAN Fidanza flywheel with an SRE 754 pressure plate and sinter disc. Can I use this setup with an 01A transmission?
BMW 740iA e38 - ProjectComment
