4x108 to 5-stud.
  • John.
    • 2615
    4x108 to 5-stud.
    Can anybody tell me what I'll need to convert my B3 CQ from 4x108 hubs to S2 5-stud ?
    Cheers.
  • Ruffiano
    • Sep 2007
    • 1458
    S2 hubs is the simplest way.
    is your car a quattro?
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      ask gavs20v here on the forum,he had some converted 4x108 to 5x112 for sale a while ago
      TWINCHARGED power,zero lag
      AEM W/M injection
      • John.
        • 2615
        So just the the hub!
        Yes, quattro.
        • John.
          • 2615
          • Ruffiano
            • Sep 2007
            • 1458
            I used URS4/6 hubs, machined 5mm off of them:
            Pressed into the front hubs. stock bearing and all:
            for the rears:
            B5 a4 quattro hubs:
            again, stock bearings and all stock axles from my b3 coupe
            • gavs20v
              • Sep 2004
              • 3057
              Originally posted by John.
              Still have these available
              Gav
              S2 Cabriolet.........
                S2 hubs are the way to go if you can. As above there are other, cheaper ways but they do involve faffing about with caliper spacers etc as the hub offsets are different.
                • varia
                  • 821
                  • Current: United States
                  i have original s2 hubs, but still had to use spacer for my brakes
                  • John.
                    • 2615
                    I hear all the above, mis-match disc to caliper carrier spacing was on my mind........obviously I'll need 4 bearings as well.
                    I'd rather go the S2 hub route.
                      • 4754
                      What wheels have you in mind and are you going S2 front bumper?
                      • John.
                        • 2615
                        Something 16" I think, not 100% sure I'll do it or not.
                        No to the bumper.
                          I guess you are not using S2 discs then
