Audi 200 20V Turbo 6 speed gearbox swap
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    I have another project started involving an 200 quattro avant.
    I want to fit the 6 speed gearbox to it...but i dont know what gearbox mounts, subframe, driveshafts..etc i need.
    Somebody has some ideas about this conversion?
    Thank You!
    All the best!
    Eugen
  • domas
    • Oct 2014
    • 307
    • Country: Lithuania
    welll it must have been documended somewhere before but keep in mind that you will need a new shifter linkage as well.
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      Thank you Domas!
      I have the gear lever with all the parts needed. 01E gearbox. But I don't know what transmission mounts I need for the 200 subframe..or I need to change that too?
      • domas
        • Oct 2014
        • 307
        Just fiddling around in the garage again with the 6-speed 01E and I thought about fitting this thing in the 200 again. I need transmission mounting brackets. Just ditched the 016 brackets 'cos, ofcourse, very different. Question is: the 5-speed 01E mounting brackets taken from a C4 bodied car...
        you will need some v8 manual stuff
        just google around: https://www.google.com/search?q=audi...utf-8&oe=utf-8
        Are you by any chance interested in selling your oem 20v linkeage to me if it has zero play in it?
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Thank you Domas!
          Friday I will take the linkage out.
          You pay the shipment. I don't need. I have the complete linkage new from Audi.
          All the best!
          Eugen
          Send me an PM with your address.
          • domas
            • Oct 2014
            • 307
            you've got a pm
            • sailaz
              • Oct 2009
              • 647
              • Country: United Nations
              custom made
              or if you change to V8 6-speed manual subframe then mounts from that 6-speed manual, which is very unlikely realistic option ...
              • Pirvu Eugen
                • Apr 2007
                • 1978
                • Country: Romania
                Hmmm!! Not great news! I have an V8 5 speed manual subframe.
                Is this the same with 6 speed manual subframe?
                Thank you!
                Is different.. different part number.
                Custom mounts is the way to go then...
                • sailaz
                  • Oct 2009
                  • 647
                  no, is not the same. but I'm not sure how big difference is, I think I was reading somewhere that it can be used with small modification.. but once again, I might be mistaking, anyhow gearbox mounts will not fit because 5 speed is 016 type.
                  I have used subframe from v8 automatic, V8 441399153C bonded rubber mountings and custom made gearbox supports (mounts)
