slave cylinder problem!
  • eXtreemeRS
    • Feb 2005
    • 56
    Anyone know a smart solution on, how to disconnect the slave cylinder on the gearbox??
    I have to replace it..
    I've heard there is only one mounting screw on it... but I cant find it of course..
  • S2 Ant
    • 3682
    If you turn steering full lock to the right it exposes as must as you will be able to see.
    The single bolt is reachable with a socket and ratchet but you will need to do it by touch.... and of course the pipe feeding it as well, but it may be easier for you to detach it from the main pipe coming down as that is v easy to get at and can then undo the end on the slave cylinder once its out of the car
    Trying to think, from memory i think you will need to detach the 2 gear linkage points to get to it clearly.
    Its not too bad to do really, just make sure you use a genuine part to replace it as i used a patent part and it fouled on the gearbox and didnt fit.
    I'll upload some pics i have at home from when i done it
    Ant
    2011 Kawasaki Z1000
    • eXtreemeRS
      • Feb 2005
      • 56
      Ok
      Ok, I think I see.. !
      Thanks man... hmm..sounds pretty easy think I'll go out and and try.
      by the way I got a 3b engine if that make any changes..
      would been awsome with some pics..
      • eXtreemeRS
        • Feb 2005
        • 56
        there it was
        The slave cylinder is out..
        very easy.. screw was hidden behind the pump..cant see it, have to feel it..
        The end at the slave cylinder was broken... splitt i half...
        just have to replace and put it in gear i hope..
