still; what P/N from clutchnet,WHAT cost for the kit??
Clutchnet clutch fitted :D
Originally posted by diesel desOk, so the 2 long pins on the clutch side of the flywheel are not needed for the ecu? Its just the 1 short pin on the crank side of the flywheel? And the dowles on the ABY need shortened to fit the box, as the spacer plate is removed. Anything else?Thanks,des.Last edited by SteveH; 18 April 2005, 22:48.91 Modded 3B
14 A6 Avant Black Edition
