What pressures for 18s?
    Originally posted by dan_b
    Same route to work? Interesting...
    Yeh, basically trial and error Dan, some people like psi high some like it low
    • Keeper of The Kitten
      • Dec 2003
      • 2317
      Originally posted by karlblues2
      The even tyre wear as mentioned earlier too, is also a function of camber set up too. Too much toe-in and the inside of the tyre will make the most contact most of the time anyway. That's the compromise with good handling / tyre wear
      Karl
      Oz
      Bear in mind that camber and toe are very different!
      Surely toe-in will increase wear on the outer edge of the tyre? At the front that is guaranteed, and I think that it will be true at the rear. The tyres are trying to push over onto the outside edge all of the time, even in a straight line under acceleration or braking.
      If you increase front static toe-out, the car will exhibit improved turn-in to a certain degree, but at the expense of excessive wear to the inner edges. Think of it as an exaggerated Ackermann geometry when the steering is at an angle. It will still be better for certain corner speeds than others.
      Rear toe-in can be advantageous for tyre scrub angles, but maybe only on the heavily loaded side of the car (outside of a turn), whereas front toe-out tries to take advantage of the tyre on the inside of a turn - exaggerating it's scrub angle.
      Anyway enough baloney, hardly ever push my car hard enough to worry!!! Tyre pressures in the 30s have never put my rims at risk, and East Anglia has officially got Britain's crappiest roads!
      __MDC__
      Martin Cutting
      • s2driveruk
        • 12696
        QUOTE: Anyway enough baloney, hardly ever push my car hard enough to worry!!! Tyre pressures in the 30s have never put my rims at risk, and East Anglia has officially got Britain's crappiest roads!
        Only beaten by Surrey....the county only knows how to throw hot tar and gravel at any road problem even on death-trap roads like the A31/hogs back - totally irresponsible in my opinion
        1992 3b S2 Coupe
          Do you guys with 18s get tramlining issues? Mine seems worse since fitting the new ARBS and replacing the top strut mounts. Can altering the tyre pressures help?
          Did you get the tracking checked after fitting the top mounts?
          Mine tramlines less on the RS4 18 x 8.5s than the old 16" Avus
          They do look a bit mental though
            I'm with you there brother
              After spending the evening testing found the best results are 38-40 psi
              • s2driveruk
                • 12696
                yep mine tramlines much less with 18's than it ever did with the 16's
                1992 3b S2 Coupe
                  • Dec 2003
                  • 2317
                  Hehehe! We only get the tar and chipping solution around here too - even on the death trap A140!
                  __MDC__
                  Martin Cutting
                    Bloody! Just went out and they've tar/chipped the corner at the bottom of the hill! 200yds from me and no warning between me and the corner, good job I didn't go out on the bike! What a bloody mess chippings everywhere....
                    • s2driveruk
                      • 12696
                      give it two months a bit of hot weather and you'll be back to two lethal stripes of slick tar and all the chipings in the middle :LOL:
                      1992 3b S2 Coupe
                        Haha, make that 2 days....
                          I like 38.
                          @ Mark H, what offset are your wheels BTW?
