Will these fit?
  • Allybingo
    • Jul 2004
    • 65
    Will these fit?
    Ok i have adapters first of all 112 x 5 to 130 x 5.
    My worry is will they stick out of wheel arch too much i know rs2 cup alloys are fine but some are different!
    I need somebody who understands the figures.
    http://cgi.ebay.co.uk/Porsche-Cup-1-...QQcmdZViewItem
    hope this link works.
  • s2avant95M
    • 1217
    • Home: England Current: United States
    I doubt youll get 9J to fit.
    Tim
    1995 S2 Avant, ruby red - ** SOLD TO ROSS **
    Golf Rallye G60 ** SOLD **
    Golf MK2 Oaky with R32 engine
    Audi A6 Avant 1.9 TDi 130
    Golf MK2 8v Race car
    • Allybingo
      • Jul 2004
      • 65
      When you say 9J does that mean the rears will stick out a bit?
      • BRY
        • 3755
        What thickness are your adapters?
        • Allybingo
          • Jul 2004
          • 65
          Not got them with me at the moment but about 4 cm ,what code are the rs2 cups are they the same all round front and back?
          • s2avant95M
            • 1217
            7J all round
            Tim
            • rotoryboy
              • May 2004
              • 3281
              Originally posted by Allybingo
              about 4 cm
              40mm??
              Mark
              Race Clio RS197
              S2 Coupe ABY (Green) - RIP
              S2 Coupe ABY (Blue) - Sold
              • Allybingo
                • Jul 2004
                • 65
                oops sorry i mean 40mm
                  40mm Spacers!!!!!
                  **** me your wheel bearings will need changing every 20K miles!
                  • Allybingo
                    • Jul 2004
                    • 65
                    oops again got it wrong 30mm is the depth of the adapters. i should never guess!
                    • volcano rs
                      • Jun 2005
                      • 2265
                      make your mind up next post you might come down to 20mm.
                        You'll need to find some spacers about 10mm thick for the back and they'll still be well tight. 30mm spacer on an ET47 makes an ET of 17, RS4 wheel is 8.5 ET20 and they rub on the plastic liner, with 225 tyres.. These would still be 9mm further out than that. 10mm spacer would make them ET37 which is about right but may still rub. Not sure about inside clearance.
                        Fronts should be ok.
