Hi Chaps, the problem is as follows...
As part of my project i sourced second hand front and rear sub frames that i had shot blasted, primed and re-sprayed. These have now been fitted and went straight on with all the bushes and mounts replaced using the wishbones they came with. (Cast front and pressed rears)
However, when i went to have the 4wheel alignment done the fronts were spot on yet the rears weren't. First problem was the camber adjustment. The near side rear, when adjusted for maximum camber, would only go dead plumb (ie no more adjustment left on the sliders to get the top of the wheel further in the arch?). The offside wheel though was completely the opposite. When adjusted to get the camber plumb to match the near side it wouldnt even go plumb! (ie you could adjust it for loads of camber with the top of the wheel in the arch but not the other way!!) I'm sure there's a more technical way of describing this but hopefully you know what i mean
Then we were presented with problem number 2. It seems that, when measured with spirit level from arch, the offside wheel is sitting approximately 15-20mm further in than the near side! Now i'm not sure if this is an effect of the camber adjustment problem or not but the question is what may have caused this? I'm now worried that one of the previous owners has had a prang maybe or that the replacement subframe is at fault? The car is booked in for an inspection on the ramp tomorrow afternoon but i would really appreciate it if someone could advise on what sort of things i should be either checking or measuring to find the source of the problem. It's a real head scratcher for me (not a mechanic...) but hopefully it's just something simple.
Any pointers or advice please?
Russ
P.S Did pressure test on boost hoses today. Found huge hole in one of the joins in the big pipe that goes to the bottom of the cold side. Fortunately this is also one of the ones that comes in the samco kit! Phew!
.Then we were presented with problem number 2. It seems that, when measured with spirit level from arch, the offside wheel is sitting approximately 15-20mm further in than the near side! Now i'm not sure if this is an effect of the camber adjustment problem or not but the question is what may have caused this? I'm now worried that one of the previous owners has had a prang maybe or that the replacement subframe is at fault? The car is booked in for an inspection on the ramp tomorrow afternoon but i would really appreciate it if someone could advise on what sort of things i should be either checking or measuring to find the source of the problem. It's a real head scratcher for me (not a mechanic...) but hopefully it's just something simple.
Russ
