The Coupe runs a wider track than the saloon. Are you running all Coupe bits, all saloon bits or a mixture ?
Puzzled...
Basically it's just the bracket/flange that was changed over. That's the only shared item. I have fitted non saloon subframes though. Would that make any difference? The car has QRSport coilover suspension.
I wish i knew how to attach photos to posts... Have loads of shots from under car showing all the mounting points etc that we're talking about
Old Stuff Reborn.Comment
This was right near the top of the thread and really needs correcting!Originally posted by BibbyTop of the wheel toward the middle of the car = positive camber.
That's the extent of my input to this thread... my work here is done.
For the uninitiated, when the top of the wheel is inboard (nearer to the centreline of the car) compared to the bottom, it is negative camber.
We might refer to "adding camber" or using "more camber" ...but what we really mean is "more negative camber" (as we are unlikely to want to go the other way).
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
Good to know, cheers Mike. (My rear subframe does have an ARB btw so at least i have the right one!)Originally posted by Mikes2I've only just checked this - the saloon and Coupe subframes are the same, providing they both have rear ARBs.
We're having a look at this tomorrow. Hope it's sortable by moving the subframe only...
I'll post the results tomorrow evening when i get back.
RussOld Stuff Reborn.Comment
Surely an alignment specialist with the right optical gear can quickly determine that the subframes are mounted squarely to the chassis. This should be checked before attempting to set front/rear toe, camber & Caster (where applicable).
PaulPaul Nugent
This sort of thing is always a difficult issue, as you need to have suitable reference points (and you'll be aware of the intricate shapes on the shell of a road car).
However, it should still be possible to get comparitive measurements for the left-right positioning of a subframe. Given the fairly large discrepancy in this case, it almost sounds like there should be another set of holes beside the first set!
My first action would be to measure the subframe at the wishbone mountings to a suitable location on the shell (mid point of wheelarch opening, jacking point) and compare left-right for those cases.
Next would be to compare the actual mounting holes for the subframe left-right.
It is very unlikely that the mounting holes in the shell are that far out, unless they have been substantially tweaked in an accident?
Right then, the latest....
Had the car up on the ramp today and followed all instructions given but with no success at all...
There was a bit of movement when the subframe bolts were undone but nowhere near enough to get the movement that is needed to center the whole assembly
Unfortunately wasnt able to remove the subframe completely to do the 'measuring to reference point' task but we agreed that there wasn't any evidence of any major collision damage so ruled that one out for the time being.
So... all we could think it could be is the subframe i fitted?? It was second hand and at the time was presumed to be straight even though its history was unknown.
Dean @ ALL AUDI is sourcing another subframe to try and we'll fit it initially with the Oem rubber mounts and see if this makes any difference.
To be honest, if it isn't the subframe that's the problem then i'm stumped as to what else it could be.
What do you think chaps? Is this the right next step to take or am i wasting my time and money?? Would appreciate your comments.
I think you're spot on here KOTK. I'll make sure that these measurements are taken like you say. This should be a definitive indicator as to whether the subframe is at fault or not. Thanks for giving it thoughtOriginally posted by Keeper of The Kitten
__MDC__
@ Paul. It was 4wheel aligned at Demon Tweeks and they never even mentioned the fact that the subframe was out of line or anything. Their only suggestion was to elongate the holes on wishbone section to gain more camber on both wheels!
there rep on this forum seems to be going down hillIt was 4wheel aligned at Demon Tweeks and they never even mentioned the fact that the subframe was out of line or anything.
Russ
You do have all the correct ball joints and wishbones on don't you?
You haven't mixed and matched on any of those components?
Worth a quick check before you pull off everything else.Kingdoms are run by Kings, Dictatorships are run by Dictators.
England must be a Country. :mischeif:Comment
It's booked back in next Tuesday. Have got a spare subframe from a 90 20v q to try also. Before the existing frame comes off there will be a whole series of dimensions and measurements taken to rule out exactly the sort of thing you have pointed out Bry.Originally posted by BRYRuss
If it is what you say, how and which one could have been fitted in error? I assumed that if it wasnt from a 90q or S2 coupe it wouldnt fit anyway?
It's bloody confusing all this. I'm really hoping it's something straight forward.
Hi all,
I thought id share my experience.
My s2 was pulling to the left for about 3 years, after many bushes, wheel alighments, new wheels, tracking 5 times, ive solved it.
The front subframe mount, was shafted. the bolt which holds the bush in, screws into a nut, that nut was loose and basically shafted. this has been sorted and the car tracked at demon tweeks and its all sorted!!
btw, the chap that did my tracking at DT, said this was his 6th s2 hes tracked, and I got a nice printout of the tracking results. Thought id mention this as ive not experienced such a situation b4 with any other garages apart from Tims
ABY Coupe
sigpicComment
