Good idea on the chart, S2 Central does not give all of the anwers, but it is good on the areas it does cover.
Does anyone know the part number of theearly 17" Avus wheel (5 x 112) (ET = ?) Are they 7, 7.5 or 8" in width. They may have come on an early S4 or S6. It is to allow a factory look upgrade to 17" (ideally without spacers) for an S2 with 16" Avus wheels.
Greg S, thanks for linking the two threads. Unfortunately the chart seems to be dropping characters on my screen and can't be read properly. Even after zooming it up in size?
Does anyone have the part number for the NuS6 8 x 17 Avus Rim? (5 x 112 and ET 35).
Could somebody advise what kind of an S6 is an NuS6?, and its years of manafacture and the countries it was sold in?
if you use the link you can enter the details in for your wheels and perform new calculations online. Or if you save the image to your desktop and then open it that way
Can someone explain this to me (about to start his 2nd year in Automotive engineering!!!)
Going from 205/55/R16 (std) to either 245/40/R17 or 255/40/R17.
How ON EARTH could tyre width (appart from frictional rolling resistances) effect the speedo reading by 0.6% Slower for 255's or 0.6% Faster for 245's?
Surely width means nothing but more grip and more rolling resistances (therefore possibly slower acceleration and Vmax)????
_phil
...ever since I floored you I knew that I loved you!
245/40/17 have an aspect ratio of 40% which means the height of the tyre wall at the top and bottom is 245mm x 0.4
On the 255 tyre the height of the tyre wall top and bottom is 255mm x 0.4.
This means that the 255 tyre will have a larger overall diameter when fitted to a 17" rim, and therefore a greater rolling radius.
P.S. you can work out the overall height of a tyre and wheel combined diameter by doing the following:
a 245 / 40 /17 tyre will have a diameter of
245mm x.40 x 2 = The height of the rubber to and bottom in mm
17" X 25.4 = Diameter of wheel in mm.
This is never an exact science because all tyre manufacturers make their tyres slightly differently, but it is good enough to calculate differences in speedo readings etc...
Cheers,
Steve
The Perfectionist
They probably won't teach you it. Most of that stuff is theory, you have to teach yourself the practical stuff.
Good luck, I finished my Beng 10 years ago and have hardly done a complicated calculation since....
Hands on engineering experience helps IMO.
Cheers,
Steve
The Perfectionist
I read all topic, all information in S2central but did not get a point. :-) Sorry :-(
I want to fit RH R17 8J wheels on my S2 Coupe with 245/40R17 tyres. What ET do I need?
RH wheels have ET60, but I have also 20mm spacers. So the total ET is 40. It is not enought, right?
Owner of www.audiScars.lv
ex-Audi S2 Coupe '96
ex-Audi S2 Coupe '93
ex-Audi S2 Coupe '91
Thanks for answer. But I'm not sure about that.
When I tried to fit the same wheel with 245/45 with ET40 (with 20mm spacer) it was not possible at all. Tyre touch steering rod. I somehow tried to adapt one more 10mm spacer (total ET30) and then it was around 2mm from steering rod.
Thats why I'm asking for your support. It seems that I must go for ET25.
Wheel & Tyre Sizes with % Difference Rolling Circumference
Gents I found the following information on this site which I thought some of you would appreciate as reference material. It looks like some of the tyres shown are not even made but it is pretty comprehensive.
Shane
