I have put my s4 wheels on but i am experiencing bad wheel wobble at speeds above 50mph. What can cause this? Is it a case of just getting my wheels balanced or do u think the spacers are the culprit? Its soo frustrating cos they look so good
wheel wobble
50mph wobble is typical for a badly balanced wheel, Get them balanced.
Do your spacers locate properly on the hub and in the centre of the wheel? If so they should be fine.
I have tried to line them up as best as possible but was thinking they might not be right. May get a pro to fit them for me i think.3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
Very very likely to be a not-properly balanced wheel. Go back to a different tyre shop and get all 4 wheels re-balanced. I hope for your sake that it's just an operator error or a badly calibrated machine, or that a balancing weight has fallen off, and not either a faulty tyre or a warped alloy...Ex S2 owner, now running around in an A4 Avant quattro...
The tyres were alrady fitted when i got them. I will get them rebalanced and fitted properly if this does not help then i will get some hub centric spacers from BAZ C. Does he do 10mm cos he didnt list them on the thread. Cheers3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
You must have location between the wheel and the hub, the bolts will not locate the wheel properly, you could go over a bump and knock the wheel off centre, maybe even have a wheel come off. If you have a friendly machinist you could have some locating rings made up and your spacers machined to take them. Or just get the hubcentric spacers.
Took mine to my local mechanic to fit it all up properly. Took the spacers off measured and no problems at all. So im not using spacers now3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
Cool, and no wobbles?
