Tyre recommendation for 8.5x17 et13 wheels
  • rs2coupe
    • Oct 2004
    • 1782
    • Home: Trinidad and Tobago Current: United States
    Guys I am shopping for tyres for my 91cq that will end up on 17''x8.5'' et13 bbs rs200 rims. Now the tyre shop is telling me that it will not fit on my Coupe and it may need to be stretched! I don't want to compromise performance but I also do not want the tyres tearing off of my rims. Any experience with this size rims and offset of Coupe? Recommended tyres size? Side by pic of wheels
    Cheers mis amigos,
    _Anton
    245/40/17 or 225/45/17 should fit on those rims
    As for Tyres, Toyo, Goodyear Eagle F1's or Continental Contact sports 2
    • rs2coupe
      • Oct 2004
      • 1782
      thank you Jamo.
      Cheers mis amigos,
      _Anton
      • Fat Audi 80
        • 10547
        Originally posted by Jamo
        245/45/17 or 225/45/17 should fit on those rims
        Yes, I have 245/40/17's on my 8 x 17" wheels so you will be fine. No rubbing with an ET 37 (BBS Rims too )
        Cheers,
        Steve
        The Perfectionist
        • BRY
          • 3755
          What about the ET13 bit?
          That's 20mm too far "out"
          • Fat Audi 80
            • 10547
            I think it may need some work yes....
            The Perfectionist
            • rs2coupe
              • Oct 2004
              • 1782
              lol some work? that scares me! Anyone running close to the same offset with feedback please?
              Cheers mis amigos,
              _Anton
              • BRY
                • 3755
                Abt C5 kit should cover them
                  The alloy wheel mounting face can be milled by 20mm to make them ET33
                  • BRY
                    • 3755
                    no
                    I doubt there is 20mm of metal under the head of the wheel bolt, unless BBS make wheels to use +20mm wheel bolts. Normally you can take a couple of mm off the inner face, but not 20mm.
                    • Crawford_S2
                      • 1555
                      Back wheels could fit with maybe a 'tweek' of the arches but fronts with that ofset may foul the inner arch at the front on lock.
                      Ragusa Coupe gone!
                      • rs2coupe
                        • Oct 2004
                        • 1782
                        This is bad news I did not expect.. Bry is right, need some C5 fenders:mischeif: I am going to look into schimming off a few mm if possible. Rubbing is also dependant on my ride height correct?
                        I thought I remembered forum member "Audspeed" running on Azev A 17x8.5et13 front & 17x10et20 rear.
                        Cheers mis amigos,
                        _Anton
