You guys get Kuhmo tires over there? They are becoming more and more popular in the US.
I have had several sets and I really like them. For those going for a cost effective approach...
Dave K.
USA
1991 e//S2 (home built S2 - the only way to get one in USA!)
2001 S4
Can anyone tell me whether 19" RS6 wheels ET35 (I presume I can't get these with ET40 straight out of the shop?) with 235/30R19's will work on my ABY?
Doug,
You say the 235/35R19's rubbed even at ET40? Would doing to the 235/30R19 profile tyre (rather than the 235/35R19) help enough to stop the rubbing? S2central suggests the 235/30R19 anyway...
Your getting ET numbers mixed up mate, the higher the number the closer it is the steering arms. So you'd want a lower ET number when the alloys get wider.
S2 Ant's fitted on the front fine at ET35 but he needed 5mm spacers on the rear wheels.
235/35x19 et35 rubbed only on the front. I removed the inner liner and it still rubbed. I machined the front wheels to et40 - i still got a rub on hard braking and some turning. I removed the fecking front mudflaps and no rubbing.
My car is low and is tracked and it does not rub.
ET35 might not rub at all - Ant has these on his.
stuff 19s - you can get 20" tires in small enough sizes to fit our cars now
Doug,
Hey Jamo,
Yeah I understand that.
But Doug is running ET40? IIRC, he shaved 5mm off the inboard face of the wheel which means it was ET35 previously?
I guess maybe he has done this because the car is lowered and it was rubbing at the outboard edges? But I also wondered whether it was to do with the fact he was running a "taller" profile tyre i.e., a 235/35/19 rather than a 235/30/19? That might save you a few mm in diameter as well right?
Suffice to say, you reckon 8"X19" RS6 rims at ET30 running a 235/30R19 tyre would work eh? Thats what S2_Ant runs except he doesn't run the spacers at the front (so thats effectively ET35 at the front?)?
I run ET35 all round, 8x19....... i had to space the rears, probably due to the way the tyres sit on the wheel as doud didnt have this issue...
I believe ET30 takes the wheel outward more..... ET30 all round would be a better offset if running on 8x19's, the front is tight, but not too tight, the rear had a v small rub on the spring cup, so had to use 5mm spacers to bring the wheels out enough.
Ant
2011 Kawasaki Z1000
Thanks mate.
You can always get the ET35 and then get spacers if you require them mate.
Ant is happy with his, but's he's from down sooooouth, where bigger is better
How different in overall rolling diameter is a 235/35/19 to the original 16" fitment, or even the 224/45/17 that seems "standard" on the common 17" larger wheel?
