Wheels! Wheels! Wheels!
  • dan_b
    • Sep 2003
    • 3670
    #31
    Good man!
    • SR71
      • Apr 2004
      • 330
      Originally posted by Jamo
      235/35/19
      Geez if you get the 30 profile tyres you'd have no teeth left :mischeif:
      Yeah but my neighbour has a M3 CSL with nineteens and a 35 profile tyre so I'm going to try and go one better.
      00 Audi B5 S4 MRC550
      08 RRS TDV6 HSE
      03 Kawasaki B2 ZX12R 1287cc
      • S2 Ant
        • 3682
        stick with 235 / 35 / 19's if i were you, anything more and its very much trial and error and they arent cheap tyres to play with!!!
        My speedo (according to GPS tracking) seems to be almost correct, only very slightly out from what i remember when trying it... was something like 2mph out at 60mph i think
        Ant
        2011 Kawasaki Z1000
        • SR71
          • Apr 2004
          • 330
          Just to let those who have similar designs know, RS6 rims with a ET 30mm offset running 235/35/R19's fit on a stock ABY no problems.
          08 RRS TDV6 HSE
          • SR71
            • Apr 2004
            • 330
            Rear quarter shot
            08 RRS TDV6 HSE
            • SR71
              • Apr 2004
              • 330
              Front quarter shot
              08 RRS TDV6 HSE
              • SR71
                • Apr 2004
                • 330
                Close up
                08 RRS TDV6 HSE
                  • 12431
                  Looks excellent with those wheels
                  • SR71
                    • Apr 2004
                    • 330
                    Cheers Greg.
                    It does make a big difference to how aggressive the car looks.
                    Of course with stock brakes any effect is then quickly negated.
                    Hahahaha.
                    08 RRS TDV6 HSE
                    • S2 Ant
                      • 3682
                      Yeh def looking good, can see the difference in that front wheel shot of the offset too, if your car was lower, will it foul on the arch at all?
                      As that was my fear when choosing the offsets, looks sweet tho! Now looks same as mine and needs lowering lol.
                      Ant
                      2011 Kawasaki Z1000
                      • S2 Ant
                        • 3682
                        I agree with what we were saying on PM's, need 2 ET35 and 2 ET30 from the looks of them pics, i think my ET35 on the front will be a better fit when the new suspension goes on, but the ET30 on the back would have saved me fitting spacers.
                        Ant
                        2011 Kawasaki Z1000
                        • SR71
                          • Apr 2004
                          • 330
                          I agree Ant.
                          ET30's on the rear and ET35's on the front should be the way to go.
                          If my car was lowered, there would be a problem at the front. Every now and again hoofing it, if you unload the suspension and then load it up again quick I guess the wheel is rubbing on the top of the arch because you can hear it. I can live with that because I want to get stiffer springs in the future anyway in preference to lowering.
                          Clearance with the front liner on full lock is non-existent albeit my one of retaining dzu fastners (or whatever the hell they're called) is broken so it flaps around a bit. The extra 1-2mm I might get if it was tight should just about keep the wheel clear of the liner.
                          However, I was wondering if you had two different offsets, how do you get your four wheel alignment right?
                          I'm off to get one done now.
                          08 RRS TDV6 HSE
                            Why would having different offset affect your wheel alignment if your having it changed now to spec?
                            Oh look electric rear windows!
                            • SR71
                              • Apr 2004
                              • 330
                              Hey Jamo,
                              Yeah the electric rear windows are kewl.
                              The alignment is being done only because when I ditched the old wheels, the inside edge of the front left tyre was down to the thread.
                              The toe/camber is obviously wrong and the car does pull slightly to the left.
                              I'm just getting it checked to try and get that tendency ironed out.
                              08 RRS TDV6 HSE
                              • Chris5044
                                • Feb 2005
                                • 1663
                                i get that problem too
