Rubbing
  • terrybullwon
    • Mar 2006
    • 8782
    Rubbing
    Got rubbing from my front wheels on the outer arch i thought et35, 225, 18inch has been done by every nearly every on here to sum level.
    Any sugestions?
    Chef
  • rotoryboy
    • May 2004
    • 3281
    Any sugestions?
    I have ET 30 225x40x18 and they are fine
    Mark
    Race Clio RS197
    S2 Coupe ABY (Green) - RIP
    S2 Coupe ABY (Blue) - Sold
    • terrybullwon
      • Mar 2006
      • 8782
      thats why i am confused, what make tires do you run?
      Chef
      • rotoryboy
        • May 2004
        • 3281
        I use the Pirelli P Zero's as they have a hard sidewall, also used the Goodyear Extra load thingy's and they are fine also
        HTH
        Mark
        Race Clio RS197
        • terrybullwon
          • Mar 2006
          • 8782
          may be my conti's are to soft and have let out a bit?? or maybe some companys sizes are different?
          Chef
          • s2driveruk
            • 12696
            i think it might be to do with the sidewall shape and how it tapers in towards the tread or not. I have et on my RS4 reps and they are fine so in theory you should have plenty of room. Have you been told they are 35's or can you verify on the rim somewhere
            1992 3b S2 Coupe
            • tom
              • Dec 2004
              • 282
              I can't believe that Your rims are really ET 35. It sounds simply impossible. Check the rims if possible.
                I have Conti's and they dont rub running 225/40/18 with S8 alloys running an ET33
                Which Conti tyre do you have
                The thing is Terrybullwon alloy wheel fitting is not an exact science as every alloy wheel fits different.
                ET30 would push the tyre out more to the arch not inwards.
                So in your case you would want to up the ET.
                Thing is Sal ran those on his car with no problems i'd seen them on many occassion no rubbing on an ABY so this one is a bit puzzling!
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Need the scooby team to solve the mystery
                  Chef
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    contact sport 2, might swap back to front as they are differnt they are the n1's.. whats my other options?
                    Chef
                      Are they 8" rims? They should clear easily What else is going on? Is it lowered?
                        Exactly the same as what i've got
                        Are you running the spacers or just the rims? Have you had a chance to verify the ET?
                        Bizarre!
                        • s2driveruk
                          • 12696
                          just noticed I handily missed out the ET on mine i meant to say ET30. If what you have is definately a 35 then you should be well inside the arch as stock is 37 and they are miles clear. Personally I think you either have spacers or a verbal et35 which wont be verified if you get a wheel off and see what is stamped on them....
                          1992 3b S2 Coupe
                          • s2dude
                            • Nov 2005
                            • 1631
                            Im running 19" alloys with ET 35 iirc.
                            No rubbing at all....Are you sure you havent got spacers on there??!
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              Right, just got back from a night away, had to take the slow car....
                              The wheels arent et 35 BUT! they are ET 32 so that means that they should fit even more? just going to take a few pics.
                              Chef
