Hey guys I have a audi 90 with a 4 bolt hub is it possible to convert to a 5 bolt hub? Also what is needed can I use urs4/s6 hubs or do I need s2/rs2 hubs?
hub conversion
hubs
might also need different bearing housing
my conversion for the b4 audi 80 i had no problems with bearing inner race
but on my audi 90 quattro i have s2 hubs but the problem i have is bearing center is smaller than s2 hub
my 2 cents worth
cheers
johnComment
I have a 90 20v CQOriginally posted by quattrostyleyou need S2 hubs and 90 20V axles
what do you mean? Where would I be able to get one?Originally posted by john881000might also need different bearing housing
my 2 cents worth
cheers
johnComment
setup
hi
is your front suspension the same as b4 set up(S2 ....audi 80....cab set up??)
if it is i used hub assemlies and bearing housing from S2
outer cv joints work either S2 items or as i am using 2.8 v6 outer joints...on my b4
my 90 quattro saloon is same as b3 setup thats why i have front bearing problems bearing housing smaller than later b3 /coupe setup..............
delta and bry would possibly have more info
cheers
johnComment
there are 3 diff hubs: 68 bearing,75 bearing, and 82 bearing, and 75 and 82 have diff hubbs outside housing: the 75 hub have 90mm max dia outside, and 82 have 100mm outside meshuring .... BUT some diesel's
have the spec 100 mm outside and only 75 bearing....ok??
then there are at least 4 diff senter hubs . with diff wheel base too....
ta
AUDI dont make things easy do they???
what set would you recomend???
lucky i got spare suspensin leg to try things out
was thinking in front to convert complete front to b4 set up????...........would that be better???
any ideas would be great
by the by..........................................rear drineshafts fit s2 rear hubs..........but not tried bearing set up..........would that be ok???
cheers
johnComment
How would I be able to tell if my front suspension is the same as the b4??Originally posted by john881000hi
cheers
johnComment
Originally posted by andy112How would I be able to tell if my front suspension is the same as the b4??
pm sal_s2 on this forum
He was selling a full set of 5 bolt hubs COMPLETE with hub carriers etc for under £200 iirc
Will fit straight on your car iirc
with out changing axels or anything? If so then awesome.Originally posted by s2dudepm sal_s2 on this forum
As far as I'm aware if you have a 20VQ you wont have to change any of the driveshafts, they should have the right size splines. If you are buying hubs complete with carriers then you need to be aware that there are two types of hub carriers, the B4 audi's have two 21mm headed bolts connecting them to the uprights, the B3 has 19mm headed bolts, this rule seems to apply to both front and back (though I have noticed the back seemes to have changed later). That said it is an easy problem to overcome. Your existing hub carriers should be fine with just changing the hubs to 5 studComment
and if the propshaft fit outside in the hub, they dont inside to the tranny
then you have to change the inneryoke in the tranny too. some propshaft have 8mm screw, and some have 10mm
five bolt hubs
I did this conversion on my coupe quattro 20v, a 1990 car.
I bought the parts from an aby s2 coupe, and all the parts fitted perfectly. I.e no swapping over of driveshafts / bearing housings etc. they were all identical.
Front and rear all o.k.Comment
So would you be able to list the parts you needed and which car you got them from and what other cars they come in? Im getting confused with all these different sizes.Originally posted by the pirateI did this conversion on my coupe quattro 20v, a 1990 car.
