Wheel hubs
I think in reality the only parts which I had to change to achieve this were the wheel flanges.
The rest of the suspension parts were only changed because I was shotblasting and painting the entire suspension components, so was easier to do with a spare set while still being able to use the car.
I re-drilled my existing brake disks front and back to suit the five bolt hubs, and fitted s2 avus wheels -- job done.
You will have to factor in new wheel bearings though, as they usually fall apart when you press out the drive flange, as I found out to my cost when changing the front flanges, which had new bearings in there only having done a few hundred miles as I had to change them again.
