17" by 9" on a Coupe?
  • v8 coupe
    • Aug 2006
    • 93
    Hello,
    I am new to this forum. I am looking for any info you all can give me on mounting some 17" by 9" MB wheels on my coupe.
    The specs on the Wheels are ASA AR!'s in silver 17" by 9" et 35mm weight 21.6lbs from tirerack.com. I am wondering if these wil fit on my coupe front and rear with a 3-5mm spacer. I have been told yes and no by several people, but since this seems to be the best place for B3/4 related questions I'll see what your opinions are.
    Other mods to the car are a full coil over conversion, 5-112 S2 hub conversion, custom built Big brake kit featuring 996 Rear calipers in front and S8 carriers with v8q calipers in the rear both on 2 pc wilwood rotors and custom aluminum hats.
    Thanks in advance for any help you can give me.
    Sean
    91 CQ Elanor 1.9L compound Turbo build. Fully built internals, full race oval port head, custom race cam. GT2256v and hy35 in compounds.
    • 12431
    It will be tight. I have 8.5" x 17's front and rear with 35mm offset and tyres are very close to steering arm on front. If you can overcome that issue they should fit
    • v8 coupe
      • Aug 2006
      • 93
      I have heard this. I am planning to shave a little off the tyre side of the steering arm and tig weld it up so it is still strong.
      Greg what size tyres do you run? I am hoping to get 255/40-zr17's or all for corners, but if I must I coupld live with 245/45-zr17's. I don't plan on lowering the car by much so am I looking at the 245's or 255's?
      Thanks for any help.
      Sean
      • WabTheKing
        • May 2004
        • 2567
        10x18 on the rear of a coupe
        need to roll the arches a wee bit tho :mischeif:
        • rs2coupe
          • Oct 2004
          • 1782
          • Home: Trinidad and Tobago Current: United States
          Mr. King what type of wheels are those? Breytons? great looking I've always liked those on the Dahlback rs4 avant
          Cheers mis amigos,
          _Anton
          • zlobo
            • 967
            i use RH Cup 17"x9 or 9,5" on my abt but then my car is wider
            ABT C5 Lord Of The Rings
            2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
            2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
            2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
            kostic.nu
            • v8 coupe
              • Aug 2006
              • 93
              I'd love to have an ABT CQ. I am hoping to just get these 9's under the stock coupe. I don't want to roll the fenders if I can aviod it. The main reason being that my coupe has just gotten new bumpers and I am slowly working on building up some molds for custom body parts. First on my list is a hood, which is going to take me about another 6-8 months to finish if plans go as planned. Am I dreaming these are going to fit or am I just on the edge of rubbing?
              Sean
                • 12431
                I have 225/45 17's on mine. They came with 255/40 conti sports but they fouled on the steering arm. Might have been able to make them fit with spacers etc but decided against that.
                Take a look on this thread http://www.s2forum.com/forum/showthr...ight=tyre+size
                I have posted some details so you can work out different tyre sizes etc, lee who had a green avant managed to squeeze some pretty huge rubber in, I think they were on an ET30 offset instead though.
                • WabTheKing
                  • May 2004
                  • 2567
                  no there lombards i wanted 10js for the front as well but cant get em so ave to stick with the 8.5js on the front, only paid £150 for em on the bay of theives - off a 911 porker i think
                  running 265/45/18 on the rear 255/45/18 on the front
                  regards
                  Mr. WAB :mischeif:
                  • v8 coupe
                    • Aug 2006
                    • 93
                    wouldn't having a rolling diameter difference of .4" be an issue for the center diff? I talked to one guy and we decided it might be cool to try and run a 265-45-17 on a 4k with a sport quattro style body kit. I think that the wheels I am looking at should fit considering that the hats I will be running on my brakes are ~2mm thicker then stock due to the fact that they are 9.5" in diameter (outside). So If I can get these as they are not listed on tirerack.com last I checked i'll be stuffing the fenders with massive rubber.
                    I have some more questions for you all as this place has the best advice and most knowledge on the coupes. I am about to order some shocks and springs for my coil over kit, I got just the hardware. I am thinking that due to my unusual configuration(see signature) I might be able to run a 350 in front with 400's in the rear. Does this sound good or should I bump them up with these massive tyres?
                    Thanks and this place rocks
                    Sean
                    • v8 coupe
                      • Aug 2006
                      • 93
                      Oh and to show you want I am trying to build for a hood the picture that keeps me going on this never ending project.
                      My drawing
                      Sean
                        • 12431
                        Bonnet harks back to the SQ in your drawing
                        0.4" wont be an issue, if you consider the rolling difference just from tyre wear alone
                        • Jaymz
                          • Feb 2005
                          • 16
                          Here is mine with 17" 10" wide rims. Tires are 235/40.
                          1993 S2 avant
                          • WabTheKing
                            • May 2004
                            • 2567
                            you got a side view?
                            cheers
                            will
                            • WabTheKing
                              • May 2004
                              • 2567
                              why would you run softer springs on the front?
