It can in some instances act as a stiffer rear swaybar/antirollbar. When I was racing Front Wheel Drive sedans a stiffer rear spring would allow the car to rotate into a turn better. A stiffer front swaybar had a tendency to lift the front inner tire on corner out and loose traction. We ended up using a front swaybar that was soft and stiffer front springs with a heavier rear swaybar. For us this was the best compromise.
There are two thoughts on stiffer/ softer springs and swaybars. Use a stiff spring and a soft swaybar, or, use a soft spring and a stiff swaybar. The choice depends on the inherent vehicle charachteristics and, in my case, what the rules would allow.
