S6 Avus rim 17" X 8J ET35 Will using the 235-45-17 tyre be safe
  • orsum
    • May 2010
    • 1214
    • Home: United Kingdom Current: South Africa
    I dont know why but 9 years ago I fitted 225-45-17 tyres to my S2 using the Avus S6 17"-8J-ET35 rims and now due to the age of the tyres I am replacing them. So if I am going to change the tyre size now is the time to do it.
    It appears the rim can take 225 or 235 tyres. I always thought the 225 on the rim look a bit thin on the rim. So I am looking to go for the 235-45-17 tyre.
    Does anybody know if the 235-45-17 tyre on a this type of rim will work. Is it possible the tyre can catch on any part of the body or suspension.
  • DeS
    • 611
    • Country: Poland
    This rim in S6 takes 255/40 tire so you can fit 235mm easly. IMHO 225/45 looks better and handles better. Its also comfortable enough. Your decission.
    • orsum
      • May 2010
      • 1214
      Thanks DeS
      I am planning on giving the 235-45-17 a try if I can. Definitely not going to the 40 profile in South Africa.
      • 90quattrocoupe
        • Nov 2003
        • 771
        That will fit easily. I ran 255-35-17 on those same rims. Both on the track and street. I went back to 235s, because they were lighter and taller.
        Greg W.
        • orsum
          • May 2010
          • 1214
          Just been told the Sumitomo (Dunlop) tyres I was looking at using are not available in 235/45R17 94Y HTRZ3 XL MFS and 215/45R17 94Y HTRZ3 XL MFS.
          Looks like its may have to be the Sumitomo (Dunlop) tyre 225/45R17 94Y HTRZ3 XL MFS for normal use and a 205/55R16 91V FM800A MFS on an original rim as my spare.
