Et 42?
  • Sonic
    • Jul 2006
    • 5514
    Et 42?
    Hi,
    Just checking - will the following fit my s2 coupe?
    225/40/18 5x112 ET 42
    Cheers!
    Andy
    S2Forum.com Administrator
  • s2 on the way
    • Jul 2004
    • 220
    the inner lip'll be getting quite close to the struts...
    but should fit...
    u could always run some 12mm spacers or so...
    • s2driveruk
      • 12696
      ET37 is stock on the S2 and you can go OUT to 30 without rubbing. Going IN to 42 i would expect you'll be rubbing something so def spacers required
      David
      1992 3b S2 Coupe
      • Sonic
        • Jul 2006
        • 5514
        Ahhh... so if the ET number increases, the wheel "goes in"? E.g. an alloy with ET30 sticks out more than one with ET42?
        Youve both mentioned spacers, im assuming these compensate for the higher ET and push alloy out?
        • s2driveruk
          • 12696
          thats it remember if you're using spacers to ensure the bolts are long enough....
          1992 3b S2 Coupe
          • QuattroFever
            • May 2006
            • 1360
            If you have big brakes this can be a pain too and you will need to space even further.
            I am using 15mm H&R hubcentric spacers with A4 ronals ET45 225/45/17. They clear my larger front brakes but are quite close to the suspension strut.
            I could have done with 20mm or maybe 25mm to really fill the arches and be extra clear of the susp. but they're fine no rubbing on hard cornering brake/accel.
            Volcano ABY coupe
            Ant
            • dm80
              • Apr 2005
              • 812
              I'm running 225/45/17 ET 42 with no rubbing whatsoever on 3B Coupe..
              • Crawford_S2
                • 1555
                I am running 225/45/17 on my coupe on a 17x7.5 rim, et is 35 but i am running a 15mm spacer on the rear so they are et 20 now with no rubbing issues. If i were you i would run a 10mm spacer on the front and between 10 and 20mm on the rear to fill the arches.
                Ragusa Coupe gone!
                  42 + 10 or 12mm spacers will be about right.
                  • s2 on the way
                    • Jul 2004
                    • 220
                    i've got some oz futuras 17x8.5 et 20 front and rear....
                    not quite driving yet as the car is under construction, but almost done...
                    and they seem to be fine, and they're barely clearing some 996's.....
                    but they are pretty even with the arched, arches are rolled quite nicely so we'll see......
