I want to downsize from 18" back to 16" - (I think)
  • tobodestroyer
    • Dec 2005
    • 174
    Hi,
    Let's be honest. Do bigger wheels and tyres make an improvement to the ride and handling of the car or just to the looks? I have fitted the 18" wheels from my wife's A4 and the car (S2 Avant) tracks and bounces all over the road - I want my 16" wheels back but the Mrs. prefers them on her A4 for the very same reason; the car is much nicer to drive.
    So, what I want to know is this... Am I being a big girly and not appreciating the presence of more rubber on the road, or is it a case that all wider tyres are rubbish but nobody admits it.
    I'm willing to sell my wheels and tyres or trade in for a set of 16" wheels. Pictures will follow...
    Pete
  • Wheeljack
    • May 2005
    • 219
    well, let's consider a few things...
    first, i assume by the sizes that you are talking about wheel size. typically, for the same tire outside diameter, larger wheels will result in a harsher ride. This is mainly due to less sidewall resulting in a stiffer feel. This is preferred in racing/performance applications because there is less tire deformation.
    second, you talk about width as well, but i'm not sure if there is any difference in your case--not enough information. but, wider tires are preferred for performance (up to a certain point where turning is compromised) because it is more rubber on the road which in turn transfers more power to the street and is better for braking.
    third, typically as handling increases, ride quality decreases. this is just the way is works and depending on the vehicles use, a balance will have to be made. lots of rough roads may make you lean toward plushness with your 16s whereas lots of smooth track days may make you want the 18s
    hope this helps...
    chris
    • Sonic
      • Jul 2006
      • 5514
      cab9fab
      You summed that up quite nicely.
      I've just done the opposite and gone from 16" to 18". The ride immediately became more bumpy (less side wall to absorb the impact) but is alot more grippy round corners.
      As i see it:
      18" pros: Looks, handling
      16" pros: turning circle, cost, comfort
      S2Forum.com Administrator
      • Crawford_S2
        • 1555
        Originally posted by tobodestroyer
        Hi,
        Pete
        Dude, before you go binning your rims what tyres you running and at what load rating? I went from standard to 17" ages ago, bought them with part worn tyres. The ride was horrendous until i went and put some decent rubber on with the correct load rating.
        Ragusa Coupe gone!
          great summary from cab9fab - now there is a 1st post to be proud of - welcome
          I would also suggest that the tyre and tyre pressure is part of the problem...
          Like Crwaford I noticed better cornering performance (in the dry at least) when I went from stock 205/55 on 16x7.5J (ET37) to 225/45 on 18x8J (ET35) and instantly noticed a little less comfort on the bumps. I put this mostly down to sidewall dimensions - there is just less vertical rubber to absorb the bumps. I don't have great tyres on - mid range things that came with the wheels - aint worn them out yet... I know that better tyres will improve things.
          • Crawford_S2
            • 1555
            I would suggest 17s as a good compromise. I like a lot on here feel in standard trim, the S2 was under wheeled. It was something VAG were guilty of a lot during this era. The VR6 golf only got 15" rims as standard around the same time the S2s were about and that, if you have ever driven one, really spoilt a great car IMO.
            Porsche took the S2 avant and added the mods they felt worked at the time to produce the RS2. One of the things they did was put 17" wheels on it, if its good enough for porsche, its good enough for me
            Ragusa Coupe gone!
              A mate of mine with S6 19 x 235/35s on an A6 avant just borrowed my stock S2 16" Avus to try, he absolutely loves them and I think I've lost them.. I drove the car last night and I must say its transformed, they also look pretty nice too. My S2 is on 18" RS4 reps, I think if I did it again I might go for 17s. Its worth remembering that the shocks are designed to work with a particular tyre size so a lower profile would naturally be set up with a little more compliance to compensate, a bigger tire has some bump absorbtion of its own so the shock can be set stiffer. Also suspension technology has improved, drive an RS4 and tell me its not both stiff and compliant at the same time, how do they do that??
              In stock form the A4 will probably be better set up for the 18s than the S2, but if you fitted some Konis and got them dialled in right.
              Another aspect to think about is weight, aftermarket 18s are quite often heavier than the stock wheels they replace, not a great thing for roadholding and grip as the suspension has more work to do to keep the tyre in contact with the road. Weigh the wheel and tyre together though to compare.
              • Big_kev
                • Dec 2006
                • 159
                More Behind
                I went from 16" to 18" wheels last year. And as many others found the handling of the car jumped 10 fold. Now using the car as a daily driver and need a little more flesh on the seat to absorb to shocks. Probably go back to 16"
                • tobodestroyer
                  • Dec 2005
                  • 174
                  Hey Crawford, I'm liking your line of thought. Last year I fitted new stock springs and replaced all bushes, track-rod ends and ball joints but fitted RS2 shocks as they were slightly cheaper than the S2 set. (Thanks VagParts for the tip-off).
                  So, I may very well take your advice about the 17" wheel option as chosen by the nice people at Porsche. It seems to make perfect sense. I'll get some decent tyres too. What was the original choice of rubber on the RS2? Was it Dunlop and what was the tyre profile?
                  My present tyres are Kumho Ecsta Supra (if anyone's ever heard of them). Maybe they are the reason that I dislike these 18" so much...
                  • Crawford_S2
                    • 1555
                    The RS2 came with a special 245/40x17 tyre but it is no longer available, The general consensus is to go 225/45x17 with 94 load rating. Think all the RS2 boys use them now and thats what i run on my cup reps. I run Koni shocks, poly bushes and H&R meaty springs and although it is defo stiffer that stock the tyres are a good compromise between comfort and sidewall flex. Plus if you want to run decent size brakes the standard rim is a little limiting.
                    Kumho are a well respected tyre as far as i know, cheaper end of the market but not heard anything too bad about them.
                    Should be able to flog your 18s on here no bother if you really want rid and then you can have a try at 17s
                    Ragusa Coupe gone!
