Fo schizzle m' 4 wheel drizzle!
17" Spare in Coupe Boot
I'm same as you Andy, got an original 16" in the boot and the car wears 18"s.Comment
I'll need to see what the width of the rim is compared to standard. I was just looking to swap it over for the ring but if it is too wide then that's made my mind up for me! Could get a thinner 17" rim and swap it over if that's the solution. PITA though
The problems of beng PIMP, lesson 1!Cheers'en, AndyC
Andy, forgot to mention mine is an 8" wide wheel, I'm guessing your wheel is either 8"" or thinner, either that or you'd be better running a wider tyre on something 8" wide, like 245 or above..I'll need to see what the width of the rim is compared to standard. I was just looking to swap it over for the ring but if it is too wide then that's made my mind up for me! Could get a thinner 17" rim and swap it over if that's the solution. PITA though
The problems of beng PIMP, lesson 1!Comment
Hi,
I got mine in the spare wheel space too, is also a cup 1 rep,.....17X7.5 with 225 45 tyre on it.
All I had to do was t put it in with the face of the wheel outwards, ie, you see the rear of the wheel from iside the boot, but I am sure you have tried this....!
Good luck....!
ChrisHonda CBR 1100XX Blackbird Turbo....undergoing major changes.....
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
I think your right, its the wheel width and not the tyre that may be the problem
. The std 16 in avus are only 7.5 wide, whereas the pimpish 17/18in rims are usually 8J and over.
i cant get my 18 RS4 rep in as a spare, no matter what technique i use
Brian
Have got (modern style) 17 inch Avus with 225/45's on: don't fit into the spare wheel hole. I ended up just not bothering (IIRC it's not a legal requirement in the UK?). I can fit quite a lot of junk in the wheel well without it, leaving the boot free for more useful stuff (cases of wine and beer). The 16's have directional tyres too, so would be hoping for a blow out on the correct side...
Ck.Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...Comment
would there be a posibility that you could use runflats or have a spare out of a allroad where the tyre is completely flat and folded up dont no if any1 has seen one of theseComment
I'm currently using 16" as a spare (original 3B) and that was the whole point I was making about needing to fit a suitably narrow 17" spare, as the car runs on 18" wheels and it definitely won't fit those in the spare wheel well. And with 323mm discs on the horizon I suspect the 16" won't fit over the 996 caliper. Width was always the issue!
I think we need to get the slipper wagons to carry a bootful of spares along, treat 'em as support vehicles
Martin Cutting
It's not better than sex, but it runs it a close second.Comment
