235/40/17 on Cup 1s - any problems?
  • Nj
    • Jan 2007
    • 3420
    • Home: Scotland Current: Finland
    Afternoon lads. After a bit of digging I was thinking that 225/40/17 would be best on my Cup1s when I fit them but i've just spotted a set of bargain-tastic 235/40/17s. Does anybody have any thoughts on if this could cause any problems with standard suspension? I know 245 is frowned upon because it's too big but i can't see a strong opinion on whether 235 would be OK or not.
    cheers
    1990 CQ20v
  • dubmeister
    • 522
    Main problem will be clearance The 235's will be 4mm larger in diameter and 10mm wider,
    If your car is lowered it may cause probs.
    Check for clearances when the car has weight in it as it may be fine when lightly laden but rub when heavily laden.
    • Nj
      • Jan 2007
      • 3420
      cheers for the info. what do you mean by check for clearance? You mean measure with my existing wheels and see if there's room there? hmmm. maybe I should just hang on until I have funds for 225s?
      1990 CQ20v
      • raymor
        • Sep 2003
        • 597
        I've got 235/40x18 on my Avant + lowered H&R springs and it doesn't foul at all - even when towing but it'll depend on the ET of your wheels.
        1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
        1987 CQ85RS
        1994 S2 Avant- Gone
        1991 V8 -Gone, but lives on in the TDi and CQ
        Fintray Hillclimb - 33.20s
        Doune Hillclimb - 55.02s
        Forrestburn Hillclimb - 52.61
        • dubmeister
          • 522
          what size wheels and tyres are you running at the mo?
          • Nj
            • Jan 2007
            • 3420
            depends on your definition of the word "running". erm... I have a set of standard 16 inch avus wheels to go on but i'm yet to drive the car that the cup 1s will go on because I have to put the engine in yet. It's stock suspension though.
            raymor - the new wheels are 17" 7.5J, ET 35, 5/112
            these chaps http://www.s2forum.com/forum/showthread.php?t=23527
            and there's no shame in towing. a man that tows must be doing manly things.... unless you're towing antiques, in which case you're on your own ya big jessie
            1990 CQ20v
              Ideally you should use 225/45/17 235/40/17 will be fine just use a calculator to see the speedo % change
              IIRC people run 245/40/17 as well ( Fatty )
              • Nj
                • Jan 2007
                • 3420
                Cool. cheers for that Jamo. Although i'm trying to work out if you're insulting me or referring to another forum member.
                These are the pretty things making me tingle in my happy places
                1990 CQ20v
                • dubmeister
                  • 522
                  Mount the cups on the intended car then measure up 94mm from the inside base of the rim this gives you the height and then measure 235mm across the wheel. Ifit's going to foul it will foul on the inner edge of the wing, the **** guard, and maybe the inner arch on full lock.(rear will be worse than the front)
                  It's hard to judge as unless you have run the same suspension/wheel/tyre combo you can't tell 100% if it will foul or not.
                  Looks like it may be a case of suck it and see.
                  Good luck.
                    Lol Fatty is reference to Fat Audi 80 who is running 245/40/17
                    • raymor
                      • Sep 2003
                      • 597
                      nae antiques... and nae jessies
                      1987 CQ85RS
                      1994 S2 Avant- Gone
                      • ericd
                        • Nov 2003
                        • 1240
                        Been running 235/40 on 17" by 8j's for years , no problems even with lowered suspension bits...
                        • Fat Audi 80
                          • 10547
                          No clearance problems on my coupe with those above. (Mine is not lowered, but they clear the suspension / steering arms etc.)
                          I am running an ET35 on 8" rim...
                          Cheers,
                          Fatty
                          The Perfectionist
                          • Nj
                            • Jan 2007
                            • 3420
                            cool. cheers lads.
                            1990 CQ20v
                            • Fat Audi 80
                              • 10547
                              And I'm not even Fat!
                              The Perfectionist
