ET20 on UrS6?
  • Animal Mother
    • Jul 2007
    • 1135
    ET20 on UrS6?
    Will the RS4 alloys (8.5x18 ET20) fit a UrS6?
    Can someone please give a quick explanation (or a link) as to how the ET and rim width works?
    UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
    Triumph Daytona 955i - mmmmmm :fire:
    80 dag dag :driving:
  • GT500
    • Jun 2006
    • 2181
    Don't think so!
    the et is the measurment from the wheel mounting face in relation to the wheel centre line.
    Daz have a look at your wheels, on the back they will say et35 may be. they are 8 wide i seem to remember?
    so your wheel mounting face face sits 35mm further outwards,sending more of the wheel width inwards.
    If you had no et (off set) 4" would be equell either side of the wheel.
    getting back to RS4 wheels, half of 8.5" = 4.25 to centre line, then add the 20mm to the centre line so you get 4.05 on the out side and 4.45 on the inside ie alot stuck out!!
    HTH
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • Animal Mother
      • Jul 2007
      • 1135
      My current wheel are 8x17 ET40. How much more will the 8.5x18 ET20 stick out? Are we talking stick out of the wheel arch, not closer to the suspension.
      Tried working this out but my head is cabbaged ATM.
      • GT500
        • Jun 2006
        • 2181
        At the mo you have just under 2.5" sticking outwards, most of wheel is inside the wheel arch,
        With RS4 wheels you would have just under 3.25" sticking outwards.
        Thats off the top of my head,
        dosent sound alot but it is!
        Rob..
        87 UR 20v ABY
        97 S6 Avant
        • merlin's S4
          • Jan 2005
          • 1539
          It's a no go I'm afraid. I'm running 8.5j with a 30 offset and the rears stick out past the arches. The fronts are perfect in the arches mind!! I would say that ET30 is as far as you can push it but most would recommend ET35 for the urSs.
          • merlin's S4
            • Jan 2005
            • 1539
            Would that not be 3.5" as you're also increasing the wheel width by half an inch?
            • GT500
              • Jun 2006
              • 2181
              That half inch is split between both sides, so start with centre line at 4.25.
              The above was of the top of beer head!
              Rob..
              87 UR 20v ABY
              97 S6 Avant
              • merlin's S4
                • Jan 2005
                • 1539
                Mine's not quite beered up enough yet. I'm going back to the fridge!
                • Animal Mother
                  • Jul 2007
                  • 1135
                  gasping for a beer now. Only got a can os swedish perry in the fridge. s'pose that'll do.
