Don't think so!
the et is the measurment from the wheel mounting face in relation to the wheel centre line.
Daz have a look at your wheels, on the back they will say et35 may be. they are 8 wide i seem to remember?
so your wheel mounting face face sits 35mm further outwards,sending more of the wheel width inwards.
If you had no et (off set) 4" would be equell either side of the wheel.
getting back to RS4 wheels, half of 8.5" = 4.25 to centre line, then add the 20mm to the centre line so you get 4.05 on the out side and 4.45 on the inside ie alot stuck out!!
HTH
Rob..
87 UR 20v ABY
97 S6 Avant
My current wheel are 8x17 ET40. How much more will the 8.5x18 ET20 stick out? Are we talking stick out of the wheel arch, not closer to the suspension.
Tried working this out but my head is cabbaged ATM.
UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
At the mo you have just under 2.5" sticking outwards, most of wheel is inside the wheel arch,
With RS4 wheels you would have just under 3.25" sticking outwards.
Thats off the top of my head,
dosent sound alot but it is!
Rob..
87 UR 20v ABY
97 S6 Avant
It's a no go I'm afraid. I'm running 8.5j with a 30 offset and the rears stick out past the arches. The fronts are perfect in the arches mind!! I would say that ET30 is as far as you can push it but most would recommend ET35 for the urSs.
Would that not be 3.5" as you're also increasing the wheel width by half an inch?
