Tyre pressures
  • Lee
    • 1512
    Actually, I ran 36PSi on my Bridgestone SO-2 shod 16's. They were 205/55R16 and despite 36PSi they still wore preferentially on the shoulders. Probably due to hard cornering! They should probably have been run at higher pressures I guess. I can't guage wear on my 18s yet as this is my first real set of 18" tyres and they're lasting well (despite 2 failures!). One of my rear tyres looks like it is starting to lose more tread towards the outer shoulder. It's not a geometry thing but due to the way that tyre is loaded when powering out of left hand bends (no, I don't mean roundabout exits! LOL!). I guess it all depends on driving style when deciding tyre pressures. I guess different tyre manufacturers have different recomendations for specific tyre sizes when it comes to pressures.
    Designun Limited....
    • dan_b
      • Sep 2003
      • 3670
      Originally posted by audiman
      34 psi on std 205/55/16 for everyday use
      I drop pressure to about 28-30 for track days. Bit more grip.
      I was going to say that I would personally increase tyre pressures on a track day to give the sidewall more support and help with lateral grip and stability a bit more, but Lee's already said it.
      I would match Lee's experience also of tyres wearing more in general on the left hand side - all those 2nd gear high-speed roundabouts ? Surely not officer
      • audiman
        • 4827
        Maybe thats where im going wrong then? I find that the n/s/f tyre outer shoulder wears out the fastest? Did someone mention roundabouts? LOL
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • Lee
          • 1512
          o/s/r wears on its outer shoulder fastest on mine. A roundabout is a right hand bend in the UK but the exit is a left hander which I guess, those inclined to be naughty, could be doing some drifting in the exits. Strange wear for my rears is from powering out of bends as I have stock shocks and springs with RS2 ARBs. This makes the car squat quite a bit under acceleration from around 40mph. Only happens on the track though, officer. I run different tyres front and rear which suits the balance quite well now with my shocking shockers and tired springs. New suspension needed!!
          • dan_b
            • Sep 2003
            • 3670
            #20
            Increased my tyre pressures to 36 all round last weekend. Ride is slightly harsher.
            However, on a run to Birmingham and back (about 250miles), my MPG as given by the trip computer read 28.4 for the whole round trip, which is unprecedented for me. My previous personal best for that sort of driving was 27.4 on a round trip to Chester. Could increasing the tyre pressures have made that much difference to the economy?
            In theory I suppose there's a little less rolling resistance, less flex in the sidewalls, so less wasted energy, but that much? On the way up, on the motorway, I was reading 30.4, which is bonkers!
            • Doug_RS2
              • 3847
              #21
              It definitely makes a difference Dan - but do some brake tests in the wet and see how it handles - it might shock you how bad it is - but 36psi doesn't sound too high.
              • Michel
                • 150
                #22
                36 on standard 16 is the recommendation.
                Seems to work pretty well.
                But its slipper mobile.
                On track I'd increase the pressures, gives more support to the side wall and makes the tyre more rigid.....
                • Ski
                  • 2591
                  #23
                  damb psi this and psi that.. i run on 2.4 bar.. plz dont spit on me.
                  ABY Coupe
