Paul, get some Seat brackets machined to suit 314s and fit DS2500 or Mintex CTech 1144, they'll fit nicely under a set of Avus 16s. If you want it to look good then go for grooved or drilled. Mine have taken some serious abuse at Combe and Donington with no fade whatsoever, road use will never tax them like that. Get some 225/50R16 Toyo R888s or something for summer and track use. Job doned
Useful wheel weights page
I already have the RS2 carriers ready to go. Machining in one plane of those (or the caliper of course) would get a fit at somewhere like 308mm. Wouldn'y bother with drills or grooves just for looks man. Gotta make some choices on good tyres alright...
So staying with 16" Avus keeps the stealthy look (not blinged up on the same RS6 reps as every other thomas, richard & harold) and running the biggest disc with 4-pots up front is more than enough for my needs. I want something that is ultimately better for A and B roads (meaning that comfort AND control on the bumpy stuff is important) as opposed to any accomodation for even bigger brakes and massive rubber that would be advantageous on high speed track days.Paul Nugent
Thought i'd revive this thread since I did some weighing yesterday.
17x8.5 Azev A's are 20kg WITH a 235/40 toyo, I then weighed a new toyo tire at 10kg, so calculatitionions tells me that my Azevs are weighing around 10kg (what's the difference between a new tyre and a worn tyre???). Not as bad as I thought anyway
Looking at some 17x8 Millenium Revolutions which also weigh around 10kg depending on the offset.
And for reference, a new Dunlop Dirreza semi-slick also weighs 10kg.Comment
Yep, not nearly as heavy as I thought. Still, they are getting dented and buckled quite badly so they aren't strong, trackdays are ruining them. Will soon be relegating them to "everyday road" use, and getting some other 17's which are much stronger and similiar weight.Comment
I think teh Team Dynamics Pro Race series are what I'd go for, a mate's 17x7.5" with 225/45R17 T1-Rs weighed 19kg and they're a development of the touring car alloys so I'd hope they were quite strong. THe OZs aren't supposed to be that strong, one of mine has a slight flat spot on the rim, balanced OK.Cheers'en, AndyC
Very nearly went with Pro Race but couldn't find a 17x8, all 17x7s. So found a nifty guy in Wales who will machine me a custom set of Revolution Milleniums on the cheap
Amazingly hard to find 4x108 17x8 wheels! Not ready to switch to 5x112 just yet...Comment
Forgot about this thread, i wrote down the weights of an 18" Avus with and without tyre and cant find it now
All i can remember is they were 2lbs more than the cheap 18"'s that came off the car. If anybody really wants to know i guess i can dig out the old alloys and weigh then again.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
Emailed Team Dynamics this morning regarding 17x8 ET35 5x112 57.1 centre Pro Race 1.2 and Pro Race 3 wheels, they were very reasonable priced
and weighed just 7 and 8 kg respectively (approximate). I think this is the route I will be going when funds allow.
Gents,
Earlier today whilst looking for some steel rims for winter tyres I made an interesting discovery:
3B0 601 027 F 03C vw passat 16" et 37 5/112 7j are expensive however
8K0 601 027 A audi A4 16" et 39 5/112 7j are as common as muck and cheap.
Anyway I brought home 5 of the audi ones and put one up on the scales. 8.9Kg wheel rim only. That seems very light to me. Looks aside there is no beating a steel rim on a bad road.
Fitments not confirmed yet but a quick check suggests all will be good with 4 pot brakes.
Has anybody put a 16" avus on a scales?
ShaneShaneComment
Sounds about the same as the OE Avus, they're about 18kg including a 205/55R16 tyre. Steel wheel are a more resistant to a good beating than alloys
They're a nice, functional look.
Good find, I'll add your thread to the appropriate steel wheel thread
how heavy is the air in the tyre too?
ive had a few sets of wheels. what i do believe is the tyre is as important if not more than the wheel weight. the heaviest bit is the farest distance from the pivot so to speak.
picking the best tyres is the way.
i had some team dynamics rims with falcons. they were light rims but cracked on the road too easily. i went through 2 in 12 months. i changed to a bbs rc with a yoko 539. far superior mainly due to the tyre. that was on the rado.
on the s2 i had the avus 16". went to a 17" bbs rs2 and directional eagle f1. the weight differencew was there but the extra width of the tyre made up for it. went to an 18" bbs RC and eagle f1 asem and the turn, grip and pickup all improved.
id be wary of the very light rims for raod use. much better to bend one than crack one. pick the best, lightest tyres you can.Comment
Kumho 225R18 XL y rated (ku31) weigh 11kg eachPaul Nugent
