Goodyear Eagle F1 Asymmetric
  • alg
    • Apr 2004
    • 1160
    What a great tyre. Just put these on the RS2 225/45 94Y XL.
    1 Look great with pronounced outer tyre protector giving them a great aggressive look
    2 Quality ride & low noise
    3 Great turn in & feel
    Replaced P zero nero. Need to live with them for longer to judge high speed handling (round trip to yorkshire this W/E should answer that one) & wet handling.
    Very very impressed & check the price inc vat & delivery http://www.camskill.co.uk/products.p...=m4b0s16p12745
    Alastair
    RS2
  • Rusty
    • 18953
    Just done the same myself (exactly the same 225/45R17 94Y) and wrote a thread on it here.
    Blanket / poo interface is strong in all conditions!
      good expression
      Mine should be fitted this afternoon 235/40-18 on 8.5Js
      • Rusty
        • 18953
        Originally posted by Andy_Casey
        Blanket / poo interface is strong...
        What he said
        • ADU_S2
          • May 2004
          • 164
          Ive just had a delivery of a set of Eagle F1s 245/35/18 and believe them to be a very good tyre. Hopefully get these on the car in a couple of weeks.
          • CliveH
            • Jun 2005
            • 1319
            F1 Assyms
            I've had 225/40/18s on the S2 for about a month now. Great replacement for the GS-D3s.
            ADU_S2 - 245s on an S2 with no problems...?
            Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
            Present: S4 B8 avant, MRC Stage 2
              I just fitted the 235/40-18s to my car this afternoon, wheels are 8.5J, offset is 32mm, the tyre actually just touched the steering arm at the front, had a couple of 5mm spacers luckily so fitted them but now need longer bolts to be safe as only 5mm of bolt in the hub.
              Rears went on no problem (as long as they dont grow too much at speed..) Perfect offset for these tyres would seem to be about 27mm.
              I may look into grinding a little off the steering arm so I can ditch the spacers.
              Id say with 245s you'll be struggling.
