16" rim that will clear 323x30 996 setup?
  • Jonas_R
    • 3781
    • Country: Denmark
    Ok,
    So do we know any 16" rim that will clear the 996 setup with 323x30 disc?
    I'm going to try on some BBS RG from Audi V8, they are 16" with ET35 and 5x112.
    I will post my result here, however if other people should know other 16" that will clear please post some information
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • anton
    • Jan 2005
    • 802
    lol i was selling some of these a few weeks ago, they fit pretty snug around the 314 setup so i'm not sure, ask sal if he can check as he had them off me.
    Ant
    91' Coupe quattro 20v - project
    KW V2s and other goodies
    now gone
    03' BMW 330CI - Sold
    08' A5 Coupe 3.0l tdi quattro - Sold
    57' BMW 525d M Sport Touring
    • Jonas_R
      • 3781
      • Country: Denmark
      Hi Ant,
      I know i promised you to try and fit my friends on my 996 setup. I just never got around to do it
        You need 17" for the 323 disc, there's not enough caliper clearance to cater for heat expansion.
        • Jonas_R
          • 3781
          • Country: Denmark
          Jamo:
          So what you are saying is that the rim can fit over the caliper, but there will be less then 1mm clearence?
          • Acidburn
            • 13459
            You will more than likely find scratch marks from the callipers on the inside of the wheels and the heat build up will be quite bad
            • Rusty
              • 18953
              Just run 314s, they fit a treat and I can't imagine that 9mm will make that much difference...
              • Jonas_R
                • 3781
                • Country: Denmark
                I have the 323 disc already so Iam not about to change
                Will see how the BBS RG fits.
                • Rusty
                  • 18953
                  OK well good luck, the Avus 16s had a bit of clearance with 314s so they might work.
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    How much is a bit of clearence?
                    • urs4quattro
                      • Dec 2006
                      • 100
                      Compomotive MO 16's fit over my setup ok...
                      Gonna do a test fit of some Azev A 16's this weekend.
                      1990 urquattro 20v
                      2006 A6 Dagger
                      • Jonas_R
                        • 3781
                        • Country: Denmark
                        Which setup are you running?
                        Could you provide more info the rims?
                        • raymor
                          • Sep 2003
                          • 597
                          16" Avus with 15mm spacers fit over 323 discs - and the outer line of the wheel is still within the arch line - approx 7 to 8 mm clearance
                          1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
                          1987 CQ85RS
                          1994 S2 Avant- Gone
                          1991 V8 -Gone, but lives on in the TDi and CQ
                          Fintray Hillclimb - 33.20s
                          Doune Hillclimb - 55.02s
                          Forrestburn Hillclimb - 52.61
                          • Jonas_R
                            • 3781
                            • Country: Denmark
                            raymor:
                            Why would spacers make any difference?
                            • urs4quattro
                              • Dec 2006
                              • 100
                              993 4 pots (the Movit kit) 322 x 32 if memory serves correctly. Different calipers but disc size much the same as yours.
                              Wheel is 5x112 et 25 (this is for a urquattro)
                              Always wondered if a 16" BBS RS would fit...
                              1990 urquattro 20v
                              2006 A6 Dagger
