golf alloys on an s2
  • frazz
    • Jul 2008
    • 138
    I am thinking of fitting a set of 18'' mk5 golf gti alloys, there the diamond cut 5 spoke axe head with dark gery insides, i had a set of them on my mk3 golf vr6 and they looked the b******s but don't know if they would right on s2 are there any s2's out there with these fitted so i can compare.
  • Rusty
    • 18953
    I'm sure you could get someone to photoshop this for you. Could be an interesting look.
    You'll more than likely need spacers to sort the offset. I assume mk.5 is 5x112? Mk.3 Golf is 5x100 so won't fit.
      Golf MK5 PCD is 5x112 so he's o.k
      • Rusty
        • 18953
        I'm guessing something like et50 like the A3 so 15 to 20mm spacers will be needed...
          ET45 AFAIK so 10mm spacers will do the job, I did look into it a while back but didn't fancy them in the end.
          • Rusty
            • 18953
            I think they'd suit mine in black or dark grey (cue Toju )
              PMSL @ the Toju link
                Andy -> Keep of the grass!
                • Rusty
                  • 18953
                  Looks like you can get these in replica form in 5x112 et35. That'd be the easiset way. £450 with tyres off the bay.
                  • frazz
                    • Jul 2008
                    • 138
                    i had them on my mk3 golf had to fit spacers though an they where only 17'' how does this photoshop work is a programmme you need to buy or is there someone who can do it on here.
                    • DarrenM
                      • Aug 2007
                      • 1227
                      I nearly bought some 18" Monzas for mine ages ago, nice wheel, but wasn't sure a VW wheel would be right on an Audi. (Audi's on a VW fine tho!). Be interested to see what they look like in the flesh..
                      • Rusty
                        • 18953
                        Spacers or adaptors? If they changed the PCD then you're OK, if not then they'll not fit as said above.
                        Just put up a post asking for someone to do it for you. PS is a program that costs a fortune to buy and takes ages to master.
                        Post up a pic of the wheels and the car in the same sort of angle so that they can be superimposed on the car.
                        • frazz
                          • Jul 2008
                          • 138
                          best leave that ps program then i am just about computer literate as it is
                          the wheels were bought off ebay an were 5x100 fitment i used spacers to give the golf a fatter look.
                          • Rusty
                            • 18953
                            Won't fit the S2 then. You could put one next to the car and take a side pic to see what it'll look like. I did that when changing the colour of my alloys, gives a good idea.
