I am thinking of fitting a set of 18'' mk5 golf gti alloys, there the diamond cut 5 spoke axe head with dark gery insides, i had a set of them on my mk3 golf vr6 and they looked the b******s but don't know if they would right on s2 are there any s2's out there with these fitted so i can compare.
golf alloys on an s2
I'm sure you could get someone to photoshop this for you. Could be an interesting look.
You'll more than likely need spacers to sort the offset. I assume mk.5 is 5x112? Mk.3 Golf is 5x100 so won't fit.Cheers'en, AndyC
1994 ABY Coupe - Projekt Alpinweiss -
i had them on my mk3 golf had to fit spacers though an they where only 17'' how does this photoshop work is a programmme you need to buy or is there someone who can do it on here.Comment
Spacers or adaptors? If they changed the PCD then you're OK, if not then they'll not fit as said above.
Just put up a post asking for someone to do it for you. PS is a program that costs a fortune to buy and takes ages to master.
Post up a pic of the wheels and the car in the same sort of angle so that they can be superimposed on the car.Cheers'en, AndyC
best leave that ps program then i am just about computer literate as it isSpacers or adaptors? If they changed the PCD then you're OK, if not then they'll not fit as said above.
the wheels were bought off ebay an were 5x100 fitment i used spacers to give the golf a fatter look.Attached FilesComment
