Steel Wheels
Yeah, could be worth a shot, only 2 tho and no tyres. I think that I can get hold of 5 Avii for about £200 with pukka tyres, not winter ones mind but anything will fare better than the Eagles IMO. Was joking about getting some hub caps too
1994 ABY Coupe - Projekt AlpinweissComment
Dont bank on it...summer rubber is summer rubber its all sh*t below 7 degrees compared to winter compound and is also worse in the wet by a country mile too.
Have been running winters on the a6 for the last 5years and the difference is huge, the extra siping on the tread gives massive additional traction when pulling away but also importantly under breaking too.
I've yet to have to get out and put chains on since using them and thats been the case when ascending mountain roads with loads of snow (e.g. 10-15cm fresh on it) and the weakpoint then becomes the ground clearance not the grip!
my advice is buy wise Andy, be pointless to have another set of wheels and tyres which inspire no confidence when the weather tests you
1992 3b S2 CoupeComment
Cheers David, trying to get a better idea of what winter tyres are any good, I've found www.tyretest.com good for summer tyres. Will wait and see what I can find and whether these steels fit
Pirelli, Nokian, Vredestein, Conti, Falken and Dunlop all do decent winter rubber. Had experience of Pirelli (snowsport 210's) and Nokian (WR) and see no reason to try anything else
This brings back memories of my trip to Germany back in Feb 2000. Modern cars with steel wheels was the norm, inc this early UR which i drooled all over. I can remember thinking that someday i will own a quattro.
The little Honda CRX sporting sticky Yokohamas was mine, the things you do when your young and foolish
Attached Files91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
M&S markings just mean it has mud and snow capabilities, some in an 'all season' sense, i.e. you can keep them on all year round and they will be offering better traction in poor conditions over a summer tyre, whilst others with a snowflake marking mean they are significantly better in winter conditions than a straight M&S tyre...sigpic
Not much help but saw this on zatzy
Sold ABY-stockComment
Anyone yet by chance having tested those above as sleeper wheels for 996 monoblock and 314x30 mm combo ?
Wheel Part Number -
3B0601027F 03C
Description -
16" RALLY BLACK STEEL WHEEL RIM
Size - 7JX16H2
Offset – ET37
5/112
From -
PASSAT 2000-02 (3B) WITH PR NUMBERS C4Q+1G2, C5J
PASSAT 2002-05 (3B) WITH PR NUMBERS C5J, 1G2Comment
Yeah seems to be the way, was asking on Wheels Whores, but noone seems to be knowing of any. Oh well, new set of summer wheels and refurb the ronals for winter! Woohoo! Would 205s be alright on an 8" rim?Comment
