Correct wheels for RS2
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    I was just wondering and using a wheel/tyre/offset calculator to get the best tyres for the rs2.
    apparently it brings out that 245/40/17 on ET55 and 17x7 wheels that are the original ones, are very close to 245/35/18 on ET52 and 18x8 wheels that i have now.
    can someone verify(i can only find it from websites) that the offset and wheel size of the original rs2 wheels is indeed 17x7 ET55?
  • oleab
    • Nov 2007
    • 10
    • Country: Norway
    Thats 100% correct.
    The centerhole is 73,1mm. Porsche wheels have 71,6mm.
    • lind4hl
      • Jul 2008
      • 2465
      1 more to verify it.
      my 18x8 has et 48..
      • jade
        • Jan 2005
        • 1811
        Rs2 is ET 55 17x 7J
        RS 2 580HP
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          Thanks guys,
          i had to avoid making a wrong order. I should be using the 245/35/18 as GT500 has on his, but unfortunatelly there is no $$$ for those and i want good ones to go there. So instead i stayed with the 225/40/18 for now which is only 5mm taller total diameter and proven fit. Next change is going to be the proper ones though.
          i went with the new Falken ZE912 asymmetrics now. Although the FK452 are concidered more sporty, i thought of trying those out.
          So Saturday is shoe change for the rs2 and wheel alignment as well..
          • |Maku|
            • Apr 2005
            • 248
            • Home: Estonia
            I have two MTM RS2 tuning pdf files. From year 2000 (April) english version offers 8,5 x 18“ in 5-spoke or Porsche-design wheels with 245/35 x 18“ Dunlop SP8000 tires. From 2002 (November) german version offers BBS Le Mans Felge 8,5x18 ET 56 wheels with Yokohama 225/40R18 92Y AVS Sport tires.
            Stock RS2 wheels are 17x7" ET55 and 245/40 tires. I must say that those tires are waste of time and money. I'm currently using this size on my RS2 and I have to hold steering wheel tightly all the time (otherwise car is looking for his own route). For testing I put 215/45 to the back.
              The RS2 had special tyres and stock 245 tyres aren't the same as the ones that came with the car.
              Most RS2 owners replace them with 225 width tyres on the stock rims.
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                that is true if you use the 7inch rim. If you fit 8inch rim you can still use the 245 tyre
                • veneto rs2
                  • Jun 2006
                  • 1022
                  • Country: Veneto
                  Sorry Vasilis if I hijack your thread....
                  Anyone knows if exist and where I can get a Porsche Cup1 rim on "8x"17 (replica of course) and if there's what ET will be correct?
                  We can't in Italy put "18 on the RS2.
                  The importer does'nt give us the paperwork autorisation for it...... so no way...
                  Thanks
                  Stefano
                  http://www.audisportclub.com/
                  http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    RH makes cup wheels and although i didnt have the cup 1, i think the ET is the same. I used 17x8 ET47 and they worked nicely.
                    also you can check http://www.porscheshop.co.uk/acatalo...id_wheels.html
                    these are replica and work like a treat.
                    why are the 18 inch illegal? if the total diameter is the same, where is the problem? stupid laws...
                    • lind4hl
                      • Jul 2008
                      • 2465
                      et 47-48 sounds good on an 8" rim
                      • rs2coupe
                        • Oct 2004
                        • 1782
                        • Home: Trinidad and Tobago Current: United States
                        Does 17x9 et55 on all 4 corners fit okay on RS2?
                        Cheers mis amigos,
                        _Anton
                        • veneto rs2
                          • Jun 2006
                          • 1022
                          • Country: Veneto
                          Thanks Vasilis......
                          But...... OUCH! 741 euros each!!!!
                          Sounds a lot to me!
                          About laws in Italy......
                          Wheels size it's the common nightmare in our country...
                          The clearance to record the new size on your car documents must be supply by the importer Volkswagen Group Italy.
                          I wrote them a letter regarding the problem we have in Italy with RS2s and 245/40 "17 tires..... i also attached a letter from Audi Great Britain (Thanx to someone here on S2 Forum)where it's stated that due to the NLA of the original Dunlops the RS2s tcorrect size for the RS2 with new tires it's 225/45 "17 for SAFETY reasons....
                          Also attached my car documents where them (the importer) gave me the permit to fit 225/45 "17 back in 1998....
                          Then some of our Club members with RS2s went for the request.....
                          And they permitted the 225/45 "17...... M+S only!
                          Crazy!
                          No "9" it's way too much the car look ugly and the back tires are going out of the arches.... "8" it's the best to me.
                          Stefano
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            i think the price is for 4 wheels. check again Stefano
                            • veneto rs2
                              • Jun 2006
                              • 1022
                              • Country: Veneto
                              Yes Vas you're right price it's for the set..... I'm getting old......:corey:
                              Stefano
