Correct wheels for RS2
  • rs2coupe
    • Oct 2004
    • 1782
    • Home: Trinidad and Tobago Current: United States
    Originally posted by veneto rs2
    No "9" it's way too much the car look ugly and the back tires are going out of the arches.... "8" it's the best to me.
    Stefano
    Hi Stefano. The rims I want to put on the coupe are 9x17et55. Conversion to 5x130 just as "The Spanish" did so I will have the same offset as the RS2. I am set on doing this so my question really is do I have to roll my fenders or can I just stretch the tyres? Only the RS2 boys would know this. Thanks for your response Stefano.
    oh I think they'll look good for me
    Cheers mis amigos,
    _Anton
    • GT500
      • Jun 2006
      • 2181
      Originally posted by rs2coupe
      Does 17x9 et55 on all 4 corners fit okay on RS2?
      RS2
      NO.
      8.5 is the widest on the rear. et52 anymore offset and the tyre will having a chat with the top arm on the rear.
      Coupe can sqeeze more width.
      Rob..
      87 UR 20v ABY
      97 S6 Avant
      • rs2coupe
        • Oct 2004
        • 1782
        Originally posted by GT500
        RS2
        NO.
        Your the man Rob thanks
        Cheers mis amigos,
        _Anton
          RS2
          NO.
          Also to add to that you must use either a 225 or 235 tyre depending on the make
          • GT500
            • Jun 2006
            • 2181
            no you don't! 245s on mine. No rubbing no issues.
            Rob..
            87 UR 20v ABY
            97 S6 Avant
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #21
              245/35/18 on ET50-52 is almost identical to OEM
              • PaulJ
                • Jun 2008
                • 253
                RS2 Wheel / Tyre combo, Definitive list
                Hi All
                Is it worth compiling a list of what wheel / tyre combinations will fit the RS2
                As a help for anyone (like myself ) who is looking for a set of alternative wheels
                EG, Make, Model, Offset, Tyre Brand and size, Comments lowered, big brakes etc
                At present I'm looking for a set of 18's but there is not much choice until you go to
                8.5 x 18 and then they are mostly ET56 - 58 so spacer will have to be used. Also the
                centre bore requires machining from porsche 71.6 to RS2 73.1mm size
                I've had a trawl of the various posts and there is some info out there but it takes an
                age to find. Pictures would also help greatly.
                Wheels under consideration, 7.5 x 18 ET50 Sport design (996 Model 911 wheels)
                18" CUP 1's but not splitties as GT3 brakes will not fit inside, BBS LM's until I seen
                the price
                Any opinions would be appreciated
                Cheers Paul J
                1995 RS2 Nogaro
                1971 Lotus Elan Sprint
                1974 Lotus Elan+2S 130/5
                • GT500
                  • Jun 2006
                  • 2181
                  Not worth it at all.
                  RS2 = Cup 1s. nothing else will do.
                  They can be had in all sorts of sizes. the 8 x 17 et52 looks very nice and can run the 245 40 17 tyre like they should!
                  Don't mess with perfection!
                  Rob..
                  87 UR 20v ABY
                  97 S6 Avant
                  • rs2315
                    • Jun 2006
                    • 867
                    Here you go PaulJ, Hen's teeth as Rob would say.
                    rs2315.
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      #25
                      the veloce ones i have dont like cold weather and rocks, so the clear coat on the circomference has been damaged.im looking to have them repainted on the above colours and keep the decorative screws as brushed aluminum. But overall, the best wheels i have used so far. Much better than 17inch. I think 18 is the way to go on this car.
                      Also on the 18inch, the best tyre combination is 245/35/18 instead of the 225/45/18. I will be having that as well in the future.
                      • PaulJ
                        • Jun 2008
                        • 253
                        Bbs Lm
                        Hi All
                        Thanks for the replies
                        A80Avant, I do like the veloce wheels suit it perfectly but the GT3
                        Brakes will not fit if I use these
                        RS2315, These also look the business but as you say "rocking horse s***"
                        1 website "PWS" lists cup 1's in 8.5 x 18 but no pictures, I take it this is
                        GT500's on 18
                        GT500, Again the GT3 Brakes don't fit and don't want to go to cerrametallic pads
                        Cheers Paul
                        1995 RS2 Nogaro
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          #27
                          naah you dont need GT3 brakes. The 322x32 ones are very good and last forever
                          • Skruf
                            • Feb 2012
                            • 15
                            what aftermarket wheels can you use with GT3 brakes ? I´m looking for set 18" wheels for my rs2 and Veloce RS would do the job perfectly but will they fit with spacers?
                            • Skruf
                              • Feb 2012
                              • 15
                              any RS2 pics with:
                              - 8x18 ET52
                              - 8.5x18 ET52 (will they rub?)
                              • sam80quattro
                                • Oct 2006
                                • 1496
                                paulj what size are the gt3 brakes? ive had a set of cayenne calipers and 350mm discs behind my veloce (caliper not mounted but certainly in near enough the right place) and clearance seemed fine...
