Agreed - H rating is plenty good enough... The only niggle you might get is the tyre place saying they cannot fit H rated tyres to a car which calls up something higher. They are covering their *** of course - just another reason to turn up with four naked rims.
Winter tyres for Finland?
cool. thanks lads. If I buy them here I'll get them fitted at an independent alloy specialist who probably won't grumble. In fact I'll check and see how much they can get the tyres for in case it's better.--------------------------------------------------------------------
1990 CQ20v
2001 3.0 B6 A4 Avant Quattro Sport
Use winter tyres at temperatures below +7 °C and on snow or ice-covered roads.
Only then can the effect of the ABS and ESP® driving systems be ensured in winter too.
Use winter tyres of the same make and tread on all wheels to maintain safe handling characteristics.
You must replace winter tyres with a tread depth of less than 4 mm immediately.
These tyres are unsuitable for use in winter and no longer provide sufficient grip.
As a result, you could lose control of the vehicle and cause an accident.
Always observe the maximum permissible speed specified for the winter tyres you have fitted.
Winter tyres with H rating, speed limit is 210km/h
Winter tyres with V rating, speed limit is 240km/h
If you fit winter tyres which have a lower maximum permissible speed than that of the vehicle, affix an appropriate warning sign in the driver's field of vision. ( Required in Germany)
This can be obtained at a qualified specialist workshop, e.g. from a Service Centre.
below 7 eh? sounds like the Scottish summer
Thanks for that additional information mate. My car is clocked to 160mph so that's above both speed ratings, not that I intend to drive at 150mph on the snow
I'll see what the Finns say about needing a sticker.
With my car having sports suspension as standard it's quite low. would 205/55/16s give me acceptable clearance since i'm running 225/40/18s just now?--------------------------------------------------------------------
1990 CQ20v
For use in Finland, I will strongly advise against H rated winter tires like the Nokian WR. These are specifically developed for continental Europe, and more of a rain/light snow tire.
The rubber compound is softer than a summer tire, but not nearly as soft as a proper Scandinavian type studless snow tire, so they are not nearly as good on ice.
Nokian Hakka R or Hakka RSi is what you should look into when it comes to studless tires for Finland. For studded ones, you can't go wrong with Hakka 7.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on Alcohol
ahhh... I was actually trying to work out from Nokian's website just how different they would be. Their descriptions do mention the suitability of the WR to central europe rather than nordic regions.
Do you think i'll be ok driving through sweden and finland on the first few days of November on summer tyres? So I could just buy my winter wheels in Finland..--------------------------------------------------------------------
1990 CQ20v
Originally posted by Nj View Post
Do you think i'll be ok driving through sweden and finland on the first few days of November on summer tyres? So I could just buy my winter wheels in Finland..1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
Originally posted by Sküll View Postwhat is the difference between a WR 2 205/55 R16 91H and a WR 2 205/55 R16 94H XL?
is that XL part of the speed thingy?
I'm having no luck at all trying to find Nokian Hakka RSi outside Finland.
Does anyone know about Bridgestone Blizzak Nordics? They seem to get a good write up and I have someone trying to see if he can get them for me locally.--------------------------------------------------------------------
1990 CQ20v
