Will a 18x9" ET38 wheel go on my S2 with a 225/40/18 tire without rubbing?? It has green H&R springs and KONIS on it... Dont really know how mutch it´s lowered though. it has 8x18" ET 35 now with 235/40/18,s and no issues. but i want some german style stretch on it and a little dish so i´m thinking of getting some lemans replicas for next summer and they only come in et 38.
Ragusa Coupe gone!
Yeah, I can foresee problems with the steering arms running an 18" x 9" with a 38mm off-set. Personally I wouldn't want to go wider than 8" but 8.5" maybe a good compromise and 'should' just clear the steering arms.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
the thing is, i already have 8x18" ET 35 and i think they look well lame. i want more width, like a german style golf=) thin tire and wide rim. but i don´t want to overdoo it. but the wheel i want is only available in 8 or 9 inches wide.. but if you all say it will rub wit a 9 inc then i wont bother. ill get some 5mm spacers or something for the wheels have got now, or buy the 8" lemans and space them out.
It can be done but it's not a simply case of buy and fit them, some work is going to be needed
IMO to make the above work you'd need the front arches rolling anyway for 9" alloys to be on the safe side and then use 5mm spacers and it will be ok on the front.
I would say you may possibly need a thin space to clear the steering arm then run a 225/40x18 to get the stretch and the arches shouldn't need a tweak. Possibly on the front but the back has stacks of room. I run 17s on the back with an et of 20 and i still have room in the arches. Its also as low as i can go. The avant is slightly different but 9s or even 10s on the rear of an coupe should be easy!
Ragusa Coupe gone!
