What's this whump whump noise !!!!
  • philKS2
    • Sep 2006
    • 370
    OK..get this...
    I had a problem with the car hopping a little when on reasonably tight lock at parking speeds and also some vibration at 50-60 mph... so figured I needed 4-wheel allignment and balancing. Alignment DONE and the hopping ended
    But the vibration (through car more than steering wheel at 60mph) seemed worse.. so I went to get wheels balanced and ended up buying four new tyres (two bald and one with 2 nails!).
    NOW the car clings to the road well... and really feels great EXCEPT on straight even roads I can hear a "whump whump whump" noise like a distant helicopter ! (no it's not Avon and Somerset's finest trying to keep up!!!)
    It gets more noticeable the faster I go. Most audible at 60. Putting the car in neutral makes no difference. Sounds a but like road noise, but is more audible on smooth roads than on concrete or uneven.
    Could it just be having four brand new tyres??? It does not sound right ... and I think it's a little louder if I go round a gentle left bend than a right hander.
    Any thoughts please?
    SOLD !
    My first guess would be a worn CV joint starting to let go
    but could be a wheel bearing, perhaps prop centre bearing or rear diff needs a bit more oil / oil change?
    • Dpicariello
      • Mar 2006
      • 621
      I had exactly the same issues as you had, wheel hop etc. Alignment seemed to cure mine too. With regards to the noise i agree with Alex in that it's probably a worn prop bearing.
      • philKS2
        • Sep 2006
        • 370
        hmmm - got me thinking.. I used the diff lock a few times in the snow - first time in months if not years I've used it.. could that have triggered something? Maybe it was seized or summat
        SOLD !
        • re2500
          • May 2007
          • 2185
          I would have said Prop centre bearing also.
          Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
          "Difficult is worth doing"
            I'd say it sounds like a bearing or maybe a CV joint... though in saying that the CV joints generally only complain when turning corners... same for wheel bearings really.
            Gearbox & diff could be worth investigation, but I'd go after wheel bearings and CV joints first of all.
            • Mikes2
              • 1704
              they did torque the wheel bolts correctly ?
              Mike
              http://www.s2-audi.co.uk
              • archiboy24
                • Sep 2003
                • 286
                Yep, check the wheel bolts. Make sure they're at 85 ft lbs. Could also be a rear wheel bearing. Check by grabbing the wheel at the top and moving it in and out with the car on the ground.
                Ben
                Calgary, Alberta
                Canada
                1991 CQ e//S2 w/ RS2 spec 3B 20vt
                Panther Black Metallic
                www.moda-architecture.ca
                • denniselbows
                  • 740
                  Wheel bearing I would say as my car has had 6 in the last 8 years.they can make some strainge noises and all it takes is the minutist spot on one of the balls or races and they will make a noise with no play in.
                  never set your expectations to high that way you are never disapointed
                    Stickers still on the tyres?
                    • Alistair E
                      • 479
                      I just had new tyres fitted on the front at Christmas. They're Yoko S306's. From the moment I drove out of the garage the road noise has been unbelievable. It's not deafening but I'm going to have to do something.
                      First thing is going to be swapping front to back to check if it is actually the new tyres. Sounds too noisy to be tyres but you never know. It's definitely wheel speed related.
                      Radio's getting a bit difficult to hear with that and the brake noises that have plagued me for god knows how long. To top it all off aswell, tw***d a massive pothole the other night. Have no idea if there's any damage yet but it was quite a loud bang. Oh, but the rear tyre is now deflating overnight. Council have also filled in the hole before I had a chance to take any photo's.
                      • urS6Tom
                        • 773
                        I drove over a very sharp drain/pothole combination a month ago which burst my front right tyre. Fairly annoying. I wondered whether I had too much tyre pressure. I was running at 34psi on a 235/40/17 Bridgestone Potenza.
                        Changing the wheel in the snow involved a fair amount of swearing.
