Best ET for 8x18" RS2
  • smiler
    • Nov 2008
    • 435
    May be looking at new rims... what is the optimal ET for 8x18"?
    I have ET52 on the rims i'm using now 8,5x18".
    Or should it be the same?
    Can't know everything
    /Thomas
    RS2-94
  • lind4hl
    • Jul 2008
    • 2465
    My one“s were ET 48, you can maybe go a little lower, but im not sure on Et for best weel-fit
    • smiler
      • Nov 2008
      • 435
      Will 8x18 ET45 work????
      /Thomas
      RS2-94
      • PaulJ
        • Jun 2008
        • 253
        Hi did you have any hitting problems with the 8.5 x 18 ET52, Was the car lowered and what tire size 245/35 by any chance, There is quite limited choice in 8 x 18 as its not a normal porsche front size
        Paul
        1995 RS2 Nogaro
        1971 Lotus Elan Sprint
        1974 Lotus Elan+2S 130/5
          45 on an 8 will sit 1mm further out than 52 on an 8.5.
          • smiler
            • Nov 2008
            • 435
            Paul
            On my 18x8,5 i have 235/40 not lowerd when they where fitted... now it is.
            Had som hitting when steering big etc, realy bad suspention also.
            The "Porsche" rims i'm looking at are 18x8 ET45... Quite common frontsize from that brand.
            Not impossible then
            Its like a 8,5 ET51?
            /Thomas
            RS2-94
              Yep should be. The difference between 8" and 8.5" is 1/2 an inch or 12mm which means 6mm extra each side of centre of the rim.. so you'd need 6mm less offset to be the same distance from the wheel arch.
