I had a little bit of bad luck yesterday.
The little black plastic peg supplied with the jack snapped clean of yesterday when refitting the wheel. Thats what happens when you try to remove and refit a wheel in a very confined space.
The shaft of this is hollow so I tried gently knocking in a slightly over-sized Torx bit into the hole to grip it and unscrew the offending stud. Unsurprisingly, this just shaved the interior of the hole making it that bit wider.
I thought I could use this to my advantage and try sucessively larger Torx bits to clean out the hole and then pick out the rest with a small jewelers flat blade.
This worked well up to a point, but removing the last remnants of plastic out of the threads isn't so easy.
Would a M14x1.5 second/intermediate tap be all that is needed to fix this? Or maybe a taper tap would be better?
Any other hints, tips or advice would be much appreciated.
Thanks.
Thanks.
