RS2 BBS LM's
  • PaulJ
    • Jun 2008
    • 253
    RS2 BBS LM's
    Hi
    Does anyone have LM's on there RS2. I'm looking for the details to order a set
    ie LM099 8.5 x 18 ET??, LM141's 8 x 18, centre bore size 73.1, Any pictures would be good showing caliper clearance as I've 6 pot calipers and my local wheels supplier doubted that they would clear, Can't see why not as they would fit a porsche and its all porsche disks calipers etc
    Any info would be appreciated as they are a bit on the pricey side to get the order wrong.
    If anyone has the drawings showing clearance etc for the wheel numbers above I would be able to measure and find out if the would clear
    I've a GT3 mk1 wheel which is also BBS and this looks like it would clear OK on the disk / caliper setup I have.
    Cheers PaulJ
    1995 RS2 Nogaro
    1971 Lotus Elan Sprint
    1974 Lotus Elan+2S 130/5
  • lind4hl
    • Jul 2008
    • 2465
    centrebore 73.1 fits perfectly on my car
    • TideRS
      • Dec 2005
      • 61
      I have LM099's on my RS2. They are ET56 while LM141 are ET50. At rear no issues with 225/40 tyre but at front I had to use 5mm spacers. They clear calipers with quite a margin, I have 996 GT3 mk1 4- pots, but was too close on the inside. Can't remember if it was the coilover or the steering arm. I wouldn't use any wider tires.
      • PaulJ
        • Jun 2008
        • 253
        Everyone with 8.5 x 18's some advice needed
        Thanks for the replies
        Was concerned about clearing the calipers, this does not seem to be an issue
        I believe various people have 8.5 x 18's with 245 tyres Can any of you let me know whether they foul the arches or arch liners, The offsets used and also tyre type as not all are equal, Car is on HR coilovers so sits quite low 625mm ground to top of arch
        Was there any problem with stud length in using a 5mm spacer
        Cheers PaulJ
        1995 RS2 Nogaro
        • PaulJ
          • Jun 2008
          • 253
          Thanks, Is it LM's you have
          1995 RS2 Nogaro
          • tecknoquatt
            • Jan 2008
            • 131
            click his garage link.
            ______________
            • fridtjov-audirs2
              • Jun 2005
              • 131
              • Country: Norway
              I have 8,5 x 19" on my rs2
              • GT500
                • Jun 2006
                • 2181
                Cheers PaulJ
                My cup 1s are 8.5 18 et52. with 245 35 tyres. front has a 3mm spacer to give enough clearence to the steering arm.
                First tyres were Dunlop track day stickys. they were very wide for a 245 had to tickle some material off the rear upright.. on Federal track day tyres now and they are much narrower and clear the rear by miles. I don't get any rubbing, on lowered H&Rs. I used to get the front to rub very slightly but since fitting track density top mounts no more rub! must have been the green mounts moving sideways when cornering hard.
                hth
                Rob..
                87 UR 20v ABY
                97 S6 Avant
                  On a seperarte note, how are you finding the track density top mounts? I bought some for my car as with the heavier diesel block I thought it would be a good idea
                  • PaulJ
                    • Jun 2008
                    • 253
                    GT500
                    So with the 3 mm spacers that will take it down to ET49
                    Dilema the BBS 8.5 x 18's are ET56 that would then mean I need something like
                    a 7mm spacer, Unsure as to whether the studs are long enough but I surely can't be the first person to have this problem
                    Or do I go for the 8 x 18's ET50 LM141's which should fit on without any problems
                    but now not sure if they clear the calipers
                    Rock and a hard place come to mind
                    PaulJ
                    1995 RS2 Nogaro
                      ET50 alloys further away than TideRS setup
                      I.e he's running ET 51
                      The issue is running 245 tyres, if you run 225 you won't have clearance problem
                      • GT500
                        • Jun 2006
                        • 2181
                        I like them for better feel and knowing the strut is staying where it should!
                        Don't like the pot hole contact. A small hole sounds like the BIGGEST hole you ever hit before! makes me cringe!
                        Paul,
                        If you can get 7mm hub centric with longer studs then I'd go for them.
                        No more on the rear needs to be 52 with 245. my wheel is just under the arch.
                        #245 no curb rash! + more grip!
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                        • TideRS
                          • Dec 2005
                          • 61
                          I do not like how the rear's stick out even with 8.5 ET56 with 225/40 tire. If I could afford it, I'd go for custom 8.25x18 ET59 rim with BBS LM center. Same on the inside and from the outside it's 6mm narrower.
                            Originally posted by fridtjov-audirs2
                            ET52?
                            • PaulJ
                              • Jun 2008
                              • 253
                              Now that looks the dogs ****ocks
                              Now that looks stunning, would consider these especially as summer wheels
                              Hi Can you give me more information on these
                              Are they LM 169, 8.5 x 19 ET50, Do they hit anywhere, What type and size of tyres are you using, Whats the ride like
                              Thanks in advance Paul
                              1995 RS2 Nogaro
